Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th December 2009, 08:01 AM   #1
Session is offline Session  Norway
Default Build a psu
My psu does not work. The one I have is http://www.lcaudio.com/images/ZapPulse/ppsudia.png
Is this I good design to repair? I mean, I can just order new parts and solder to the pcb. Or should I build something else? I do not need the 0 16 gatedrive stuff.
Best regards
Old 11th December 2009, 04:44 PM   #2
Seems simple enough to repair. What has gone wrong with it?
Those 10000uf 63V caps look like they are 'sailing a bit too close to the wind', with 60V on the supply line!
I'm no EE, but I might be inclined to swap them for something with a higher voltage handling capability. Maybe even parallel two 6800uf or 8200uf items as well.
Old 12th December 2009, 03:41 PM   #3
I am pretty shure the rectifiers are shot. I have orderd new ones so hopefully on monday I will test them out. I am going to buy new caps later when I have gotten this thing up and running again. I will consider your advice
1st build done. bloozestringer Tubes / Valves 8 14th January 2009 01:22 AM
my first build... hardcory Instruments and Amps 1 5th April 2007 06:47 PM
What to build with +/-65V? Lovan Solid State 1 26th February 2007 04:26 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Page generated in 0.08705 seconds (71.90% PHP - 28.10% MySQL) with 10 queries
