My transformer
My transformer
Old 5th December 2009, 11:48 AM   #1
livenicely is offline livenicely  Pakistan
Default My transformer
I have attached bridge and caps on the transformer as u can see. Is that ok???????/
The second single cap bridge is 12volt dc for indicator and decorating lights additional feature of transformer???/ i powerd up tda2030a and tda burnt with snoke in 2 sec. is this power transformer ok for lm3886 or there is chances of burning? i hav 8 ohm 6 inch woofer.
Old 5th December 2009, 12:43 PM   #2
measure the DC output voltage at the rectifier/smoothing cap.
How small/big is that EI transformer.
I see 25+25V and 3A. But, it does not look like 150VA. It looks more like a 20VA to 50VA transformer.
regards Andrew T.
Old 5th December 2009, 01:34 PM   #3
u mean its not 3A transformer. i ask the same question from the maker of this transformer and he told me that the size of the transformer depend on the core and winding. it is 3a transformer. but y u say that its look like 20 to 50 va??? this transformer cost me $4
Old 5th December 2009, 01:48 PM   #4
how big is the transformer?
Length =
width =
height =
regards Andrew T.
Old 5th December 2009, 02:00 PM   #5
it is
height of core 6 cm
lenght of core 7.5 cm
width of core 3.5cm
i m now really worried.
i can send u high resolution pics
Old 5th December 2009, 02:19 PM   #6
I estimate from the pics and the sizes that the winding aperture is ~36mmx13.5mm, ~4.9sq cm ~0.75sq in and the centre leg of the core is ~24mmx34mm.
This gives the core area of ~ 1.25sq in =~8sq cm
Can anyone tell us the VA rating for these areas?
What is the diameter of the secondary wire?
What is the diameter of the primary wire?
regards Andrew T.
Old 5th December 2009, 02:24 PM   #7
sorry i cant tell u this. leave it. thank u so much but just tell me i did this wrong i mean attached caps an bridge direct on transformer or it is ok. i can closed this transformer in side a box or i need to make a proper pcb for bridge
Old 5th December 2009, 02:31 PM   #8
regards Andrew T.
Old 5th December 2009, 04:51 PM   #9
Elvee is offline Elvee  Belgium
Elvee's Avatar
About 64VA if the iron is of a good quality. By the look of it, I'd rather say ~50VA.
Old 5th December 2009, 06:47 PM   #10
My transformerHide this!Advertise here!
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 10:35 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 06:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 11:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Copyright ©1999-2017 diyAudio
