I'm a bit of a noob when it comes to the art of voltage regulation so forgive any stupidity... I have the Zapfilter2 output stage hooked up to my DAC. It consists of a 15-0-15 toroid, a PSU board and the Zap board itself. The Zap board has shunt regulators on board, whilst the PSU consists of a a Schottky-diode bridge providing two rails, smoothing caps (2200uF/40V), and finally the series output resistors that are necessary for the shunt regs to work (56R/5W). The rectified voltage is +/-23V and the output is +/-10V under load (regulated by the shunts). Also, my mains here in London never drops below 240VAC and is usually up around 250V, not the 230V it was designed for. I was thinking of adding pre-regulation to the PSU, so the pre-reg can handle the line regulation and the shunts the load regulation. I just want to see if the sound improves or gets worse by doing this. Currently, with a drop across the 56 ohm resistor of 13V, I make that 230mA and the whole thing gets a bit too hot. LC Audio later increased the resistors I believe to 100 ohm, but some users had to bring them down again to somewhere in-between to counteract line ripple. I read somewhere that 68-75R is optimal. I briefly switched to a 12-0-12 toroid (18V-10V/56R=140mA) and got a bit of hum myself actually. I was thinking that if I eat up a few volts with an LM317/337 in series before the resistors I will get the current down to about 180mA and get better line rejection, killing two birds with one stone. I can decrease the resistor of course to bring the current back up again if I need to. Anyone see anything wrong with that? Another option (I think) is to use the LM317/337 as a CCS. Is this a better idea? I'd need a bit more guidance as to how to do it though. Thoughts and flames welcomed. Cheers! Glenn |
| Zapfilter | vizion | Digital Source | 0 | 25th May 2008 02:24 AM |
| WTB Zapfilter | iwok | Swap Meet | 0 | 9th December 2007 11:48 PM |
| zhaolu or zapfilter? | cerondipity | Digital Source | 6 | 13th September 2007 04:34 PM |
| tda1541 + zapfilter how ? | TJ | Digital Source | 0 | 25th December 2006 07:33 PM |
| WTB ZapFilter | markmelheim | Swap Meet | 0 | 20th October 2005 07:29 PM |
| Page generated in 0.06987 seconds (70.17% PHP - 29.83% MySQL) with 10 queries |
