18VAC transformer, what to do with it?
Old 29th November 2009, 04:10 PM   #1
asbus is offline asbus
Default 18VAC transformer, what to do with it?
I found a transformer lying around on my attic, so I thought I could build an amp with it.
I see there's only one AC secondary output, could I get +/- rails with that?
If so, I could use some tips on nice solid state amps running with +/-25VDC.
I understand I won't get much power out of 25VDC, but it would be fun to do something creative with it instead of throwing it away!
Cheers
Old 29th November 2009, 04:56 PM   #2
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
That trans is only 45VA, which is VERY small for a power amp. Also, with full wave rectification and no centre tap, all you'll get is +25VDC, forget about -25.
You CAN build a power amp with it, say something like a single-supply gainclone, but I would recommend you think along the lines of preamp or headphone amp.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 30th November 2009, 03:27 AM   #3
paulb is offline paulb  Canada
Use double half-wave rectifiers to get +/- 25V. It will power an LM1875 amp very nicely. Look at the datasheet to see what power you can get. You'll need a heatsink.
Old 30th November 2009, 06:02 AM   #4
Geek is offline Geek
Geek's Avatar
Seems like a good transformer for making a tube amp with 18V (PLxx for european) heaters to me
Cheers!
Old 1st December 2009, 03:17 PM   #5
Pano is offline Pano  United States
Pano's Avatar
That Gregg - he has toobz on the brain!
Since I have T-Amp on the brain - how about an AMP9 from www.41Hz.com ? Easy to build, sounds nice. Just right for your 18V tranfo.
Take the Speaker Voltage Test!
Old 1st December 2009, 03:43 PM   #6
gain wire is offline gain wire  Canada
gain wire's Avatar
How about a variable power supply, either discrete (Pass transistor and op-amp feedback) or LM317?
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 2nd December 2009, 02:38 AM   #7
Geek's Avatar
Hehehehe, as usual!
Or a "FIWA"... five watt version of the SEWA
Cheers!
18VAC transformer, what to do with it?Hide this!Advertise here!
Wanted: Plitron 300VA 2 x 18VAC or similar ljfont Swap Meet 0 6th October 2009 06:17 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
F1 at 15VAC instead of 18VAC? nightfire Pass Labs 2 16th October 2006 11:06 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright ©1999-2017 diyAudio
