Account Disabled
Hello Attached is a schematic for a SMPS from a known power amplifiers manufacturer, it should deliver 1.6KW to 1.8KW Comments are welcomed. Any one intrested into more schematics, mail me. Micro |
#2 |
Are you thinking of buiding it? It looks pretty similar to this:
A Kilowatt Switching High Voltage Power Supply Nice. Im interested because Im building a TIG welder along similar lines. I also have six 48V 30A telecomms PSUs that use a very close circuit but have active power factor correction. Cheers Matt. |
#3 | |
Account Disabled
Your Becnh is amazing, I liked it, Also your project construction is amazing, I am in the process of building this supply for Audio Amplifier. |
#4 | |
But at higher frequencies, higher di/dt and dv/dt slopes are required for good efficiency, but they are not achievable reliably with wires and a point to point scheme because parasitic voltage spikes appear everywhere increasing stress on power transistors and diodes and ultimately causing the circuit to disturb itself due to EMI and fail. The voltage drop across an inductor is V=L*di/dt. This rule applies to the parasitic inductances on every wire, PCB track and on every component lead too. For example, in the class D amplifier that I'm finishing I use the parasitic L*di/dt drop across the source leads of the MOSFET to control turn on di/dt. The gate drive circuit does not allow 3V of drop to be exceeded on approx. 4nH, which translates into approx. 750A/us turn on slope. In other words, 66ns to start conducting 50A in each MOSFET, which nowadays is not crazy fast at all. Parasitic inductance of the source lead of a TO-220 case should be 7.5nH, but lead length and mounting style also counts a lot (the front side of the transistor is facing a ground plane too). Note that, in a MOSFET or IGBT, the parasitic L*di/dt voltage drop across the source lead (and source PCB track or wire, every path shared with gate driver loop) appears in series with gate drive voltage. What could be the effect of this when connecting transistors with long leads to the PCB? (Particularly when you are not considering at all the parasitics involved in what you are doing
I use to feel like the small child in The Emperor's New Clothes tale Last edited by Eva; 2nd December 2009 at 03:12 PM. |
#5 |
Its not my bench:-) and yes it is a bit wrong. especially the way he has the gate drive transformer located two feet away using twisted up telephone wire.
Just thought I would post it, he does give a good run down of the way he got over the problems. I am sure there are still many. I recently got hold of a massive transistor stack capable of 400 or so amps. This thing is wrong. It at least uses current sharing resistors (they are darlingtons 1990 style) but each row of trannys is connected to each other in turn rather than a nice star type arrangement. Good job it was a prototype and has never been used:-) It will after being reconfigured make a nice half bridge for my TIG welder project. I am glad I got it as the price of a pair or even multiple IGBTs to make up 200A or so is very expensive. Plus this will not see much over 400Hz so parasitics should not be a problem. This does not mean that I wont design it accordingly. Micro, If you are serious about building a switcher start with a smaller one. Modify an old PC supply and play about. At least its cheap. At the >1Kw level you start getting into expensive semiconductors and one blow up is enough to ruin a project and it will blow up. Switchers are hard to design and build, read as much as you can. Many of the application notes by the suppliers are more useful than stuff on the general web, but most of all build something smaller along similar lines first. Cheers Matt. Make sure you use an isolation transformer!!. Also watch out for the input caps. 380 odd volts will kill. Keep safe. Last edited by Matt.B.H.; 3rd December 2009 at 11:39 PM. Reason: caution |
#6 | |
Account Disabled
I am no longer working at the 2KW SMPS alone (since I need a lot of information's cannot find for free), there are 2 engineers engaged into this project (Fully PAID), I don't think I will fail, since this project will cost about 3000 US$ between parts and design The transformer designed at percussion-Inc, PCB in India. All parts from RS. Why not to make that supply reality? It should work Last edited by microsim444; 3rd December 2009 at 11:47 PM. |
#7 |
blow up about 50 Mosfets?
how come I did 1kw+ a long time ago, but didn't blow no fets, and I could say I had no idea what I was doing at first? What is your supply for? will it be commercial product? |
#8 | |
Account Disabled
Yep. That was because my first supply is the STUPID A&T Labs power supply. but in my 900W Half bridge, about 10 due my mistakes |
#9 |
omg, A and T Labs.... that says it all
mistakes are often expensive, I try to stay away from them as much as I can, even if that means checking everything 10 times |
#10 |
lets see this a+t abortion then?
| SMPS Trouble, wont start - need some advice! Full schematic | silversweden | Solid State | 0 | 1st January 2009 02:27 PM |
| Repair SMPS - Need help identifying SMD, schematic attached | silversweden | Solid State | 12 | 27th December 2008 05:39 PM |
| SG3526 Offline SMPS schematic need please | adi109cj | Power Supplies | 0 | 9th October 2007 02:31 PM |
| schematic for a + -30v ,300va smps | sagarverma | Power Supplies | 25 | 5th January 2006 11:10 AM |
| SG 3524 SMPS Schematic | -_nando-_ | Power Supplies | 2 | 19th December 2005 06:04 PM |
| Page generated in 0.27386 seconds (48.32% PHP - 51.68% MySQL) with 11 queries |
