Hi all :
Did any one used this web site for smps calculation befor ? my smps properties : input = 315 volt max out put = 600 volt I out = 200 mA Design of switch power supplies And can i trust to the result values that this web give to me ? |
#2 |
Looks pretty good to me
Let alone PCB design which can be a nightmare due to stray inductance ![]() The basic stuff certainly looks ok from what i can see though
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#3 |
Hi Mahmood,
If I may ask, what is the use of your PSU? During the last weeks, I built a resonant SMPS with a L6599 controller (ST Microelectronics) in half-bridge configuration. It is working well. However, I have about 1V pk-pk 100Hz super-imposed on the output (450V and 225mA), plus spikes at the switching frequency. Since this is for a vacuum tube HiFi amp, I am seriously thinking of going linear. Do you have this 100Hz problem? Cheers, Serge |
#4 | |
I know that because I made this mistake, and ended up with two times lower output voltage than calculated. What is your mains voltage ? If it's 220Vac, than your input voltage is (250-360)Vdc. |
#5 |
Hi serge66 :
I want to make two sets of that board to supply my audio amp that is based on STK4192II which can give me about 50W real at 6 ohm . this is my first issue i think i can use it for another application like HV generator to make electrical ARC between two wire etc . |
| need help with TL calculations | jmillerdoc | Multi-Way | 51 | 16th April 2009 03:56 PM |
| Mms to Mmd calculations | jaya000 | Multi-Way | 2 | 9th February 2009 07:48 AM |
| x over calculations | bcycle | Subwoofers | 10 | 8th February 2006 06:58 AM |
| calculations | lXxAndyxXl | Multi-Way | 8 | 19th October 2004 04:53 PM |
| Page generated in 0.09119 seconds (76.63% PHP - 23.37% MySQL) with 11 queries |
