Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th November 2009, 07:44 PM   #1
Default 4 Transformers?
I am starting to lay out my components for my amp and was wondering if 4 transformers could be used for a dual mono setup?
The only reason for using four, is that I found them at a very good price on ebay, but being only 120VA and with one 24V secondary, they were not really suitable to be used as a pair.
They are small enough though to fit quite easily into a regular width chassis, with room for the amp modules and PSUs.
Old 28th November 2009, 05:50 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
yes, 4 is possible to use, not what I would normaly expect for dual mono, but still
Old 29th November 2009, 06:31 AM   #3
A bit unconventional, but if there will be no inherent problems then great.
Thank you for the reply.
Old 29th November 2009, 03:51 PM   #4
Minion is offline Minion  Canada
I would measure them first and try to pair them with there closest voltages , There might be very slight winding Variations which could cause the output voltages not to be 100% same with each transformer so matching might be advisable ....
Cheers
Old 29th November 2009, 06:57 PM   #5
Cheers
Wise words. I'll do just that.
Thank you very much, once again.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
WTB : Transformers korben69 Swap Meet 1 27th June 2008 06:05 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
my new transformers! troublecomes Chip Amps 2 22nd December 2005 08:00 PM
transformers Joe912 Chip Amps 8 3rd April 2004 01:34 PM
Page generated in 0.08761 seconds (70.60% PHP - 29.40% MySQL) with 10 queries
