Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th November 2009, 10:35 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Mosfet Gyrator using the IRF840
Could I use the IRF820 instead? With the same values?
I'm thinking of building a Gyrator for my Baby Huey EL84. Maybe even two. And I have IRF820's in my parts bin.
I know very little about solid state things like mosfets, hence my question.
R1, R2 330k Ohm
C1 4.7uF
D1 ZD15
R3 33 Ohm
Q1 IRF840
Also any tips for improving this gyrator?
Old 25th November 2009, 11:30 PM   #2
Did it Himself
richie00boy's Avatar
The 820 will do less current than the 840. Look on the datasheet to see if it sufficient for your needs.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th November 2009, 10:38 AM   #3
Thanks Richard,
I'm looking at 80mA per gyrator. The 820 can handle 2,5A the 840 something like 8A. That is the spec Id.
But I'm not sure how to transfer that current rating into the rating of the mosfet as it has been used in the circuit.
I'll just build it and see...
Old 26th November 2009, 10:44 AM   #4
Another one. Where it appears the zener is the other way around?
Old 26th November 2009, 10:44 AM   #5
Did it Himself
I think at that current it should be fine. What voltage will be across it? You also need to consider the power dissipation and that you are within the device safe operating area (SOA curve) again both are on the datasheet - former in the table, latter as a graph.
Old 26th November 2009, 10:50 AM   #6
Around 360 I reckon. Don't know for sure yet. Still have to build the amp. Going to use tube recifier. And the transformer is 360 VAC.
Old 26th November 2009, 11:59 AM   #7
Geek's Avatar
Yeah.
Send R1 to a regulated voltage. You'll give it great PSRR
Cheers!
Old 26th November 2009, 12:06 PM   #8
Do you mean regulate the voltage before it gets to this gyrator? Or how should I see this?
Bas
Old 26th November 2009, 12:08 PM   #9
Geek's Avatar
Like the second image here:
http://www.diyaudio.com/forums/blogs...-follower.html
Only you want to take your output from the anode (gyrator) rather than that images source (follower).
Cheers!
Old 26th November 2009, 02:00 PM   #10
revintage's Avatar
Bas,
This is not a strict gyrator. Despite that, it has two advantages. You can adjust output voltage(vary R3) and it has a lot less ripple than a typical MOSFET gyrator. Still it has the exactly the same high Zout. C3 is not part of the gyrator.You might also change R1, C1 to your values if this suits you better.
Brgds
Lars
EQ with BJT as Gyrator wleediy Solid State 0 10th February 2008 09:00 PM
For Sale IRF840 quasi Swap Meet 0 5th August 2007 07:27 AM
IRF840 N,HEX instead of an IRF 710 N,MOS Ryssen Parts 5 10th February 2004 05:30 AM
Page generated in 0.10409 seconds (81.19% PHP - 18.81% MySQL) with 11 queries
