Account Disabled
Hi All.
I need some help selecting the proper LITZ wire, before I buy it. for my SMPS. Details. CORE: ETD59 FREQUENCY: 125KHZ OUTPUTS: SEC-1 85VAC 10A SEC-2 85VAC 10A SEC-3 20VAC 1A SEC-4 20VAC 1A SEC-5 16VAC 1A INPUT VOLTAGE:220v~ (360vdc) I saw one wire at e-bay litz wire 10/44, idont understant what is the 10/44. Anyway any help with selecting the proper wire is more than appreciated. Thanks... |
#2 |
I think the first number (10) is the American Wire Gauge and the second number is the number of insulated strands.
#3 |
I found this chart useful for wire gauge vs frequency:
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies Here is a Skin effect Calculator: TRANSFORMERS At 125 Khz you need a wire diameter less than 26 gauge to cover 100% of a solid conductor. Of course heavier gauge wire will work, but you will have derate the current capacity. 10/44 means 10 parallel wires at 44 gauge. Which is probably too small for your output (16V @1A) since 40 gauge wire can only transport about 90 ma (44 is even lower). Another option is to wind your transformer using a several parallel enamel magnetic wires. A parallel set of two 28 gauge enamel magnetic wire should provide sufficient current capacity for your 20V and 16V outputs. For the 85V@10A, you need about 8 strands of 28 gauge wire. Generally I find I can only wind up to five parallel strains before its difficult to keep them flat and even (important when you transformer has multiple layers. You will probably need to wind two sets of 4 strand per layer to get all 8. You may be able to use4 strands of 24 gauge, but I can't find the equation or a skin effect calc you will provide the max. recommend current capacity for a given wire gauge and frequency. A 24 gauge copper wire can transport about 3.5 amps @ 68 Khz. My guess is that switching at 125 Khz would reduce the current capacity by about 20%. 4 * 2.8A = 11.2 Amps. FWIW: I would ditch the 16 V winding and use a simple switching regulator to provide the 16V output. This would make regulation easier. Its difficult to have good regulation with multiple outputs. I would even suggest two outputs 1 at 85V and the other at 24V and use two adjustable simple switchers to output 16V and 20V for tighter voltage regulation. This would greatly simply your transformer design. FYR: http://www.national.com/ds/LM/LM2576.pdf 3A-Step-down regulator. |
#4 |
Account Disabled
Please note that the 10/44 LITZ wire is 30AWG outer diameter!!
Do you think if i get 20/44 will do the JOB?????? |
#5 | |
Why don't you read my entire earlier post and use my recommendation. |
#6 |
Account Disabled
I have already submitted my schematic and transformer specs, to the manufacturer, and its almost finished, so I am no longer worried about it any more, I am in the PCB design process, looking for a company who could do it.
its designed to deliver +-100VDC 10AM, 10AMP at full load!! Its costly since its the first! |
| litz inductor wire for speaker wire. | fazman | Everything Else | 126 | 20th June 2011 02:48 PM |
| soldering binding posts and copper litz wire | FrankDIY | Everything Else | 14 | 17th December 2009 05:12 PM |
| Litz wire and copper foil | Eva | Class D | 14 | 2nd July 2006 07:49 AM |
| LITZ wire | gearheaddruid | Swap Meet | 0 | 11th January 2005 05:07 AM |
| Litz Wire - Where to buy? | ClassD | Parts | 0 | 5th April 2004 06:37 AM |
| Page generated in 0.09709 seconds (75.92% PHP - 24.08% MySQL) with 10 queries |
