Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th May 2010, 07:40 AM   #11
Mooly's Avatar
This is the sort of thing that can be tweaked indefinitely... and it certainly looks like it would work OK.
A couple of things jump out,
1. The only source of base current for Q1 is R1. Perhaps a darlington for Q1 and run the error amp at lower current. Do you really need two LEDs in series... it will work OK but looks "messy"... use a zener oround 4.7 volts.
Same goes for Q3 as long as the input voltage is sufficient to overcome the added volt drop of a darlington.
2. Fuses are good... you could always incorporate simple current limiting (another transistor and low value resistor). However good fuses may be they are horribly non linear and in small values have significant resistance, so if you move R3 to the other end of the fuse it's (the fuse) is now within the NFB loop and it's non linearities disappear.
One other thing, C3 and C6. They couple the output directly via the B-E junction of Q2 to ground... and that's not good. You could easily see fast transients that exceed the rating of Q2. Test the regulator under dynamic conditions, eg a pulsed load drawing max current for say 1ms and see what happens. Repeat for 10ms, 100ms. C3 looks massive, you are after filtering HF noise, not adding a time constant
A simulation free zone. Design it, build it, test it.
Old 14th May 2010, 07:54 AM   #12
grufti is offline grufti  United States
grufti's Avatar
Everybody is going to have a different opinion:
1. darlington yes, but keep the LED's.
... Q3 might be disposable
2. add simple current limiting ... heed the R3 advice
12 volt power supply for tube amps caraudionut Tubes / Valves 9 27th April 2007 03:04 PM
how to build a 12 volt dc power supply? michelevit Class D 5 22nd December 2006 07:53 AM
How to use a 220 Volt power supply at 12 Volts in the car? Mr. Old School Car Audio 3 10th March 2006 12:11 AM
Can you adapt a computer power supply for the 5v and 6.3 volt needs? Original Burnedfingers Tubes / Valves 10 27th November 2002 11:22 AM
Page generated in 0.06752 seconds (66.68% PHP - 33.32% MySQL) with 11 queries
