Go Back   Home > Forums > Amplifiers > Power Supplies
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 15th November 2009, 11:23 AM   #1
kroto is offline kroto
kroto's Avatar
Send a message via Yahoo to kroto
Default help designing regulated PS 13v8@50A w/ IRFZ44
help me to design a simple regulated power supply capable to 50A in 13v8 with IRFZ44 ( shunt regulator maybe).
not gona be used to welding ofcourse
just want to learn designing PS with HEXFET, and IRFZ44 fit the purpose I think...
thx folks...
Old 15th November 2009, 01:03 PM   #2
djQUAN is offline djQUAN
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
what's the input voltage?
also: the words simple, regulated and 50A don't usually go together in a SMPS.
Old 15th November 2009, 01:28 PM   #3
kroto's Avatar
Hi djQUAN,
Lets assume 15-0-15 from the Trany.
A conventioanal regulated PS, not a SMPS.
maybe the MOSFET used as the pass transistor, can it be?
maybe, give me a basic circuit (a few if any?), and then give me the calculations needed or discuss how it should work with MOSFET.
like Drain Current is controlled by Gate-Source voltage isn't it? so, how to maintain these etc.etc.
sorry, not quite well know how MOSFET should work with well.
Old 15th November 2009, 03:19 PM   #4
stoc005 is offline stoc005
Default Make vs buy
A quick look at Ebay finds 12V @ 29A SMPS at $42 to $50 USD with free shipping. Use (2) of them. It used to be about $1 USD per watt but it seems that prices are much lower than that today. I will not build something if I can buy it for what it will cost me to build it. My time is worth something.
Designing and building a SMPS is not for beginners. Do you understand the magnetic components needed to design/make a SMPS?? This aspect usually is the deal breaker for most people. There is much more to it than picking a MosFET. Picking the right output filter caps can be a real challenge but those folks that know nothing about SMPS design think they must be easy since they have so few parts.
How much help will you need?? Do you want guidance only?? Do you want somebody else to design it and hand you the completed design?? Go to Linear Tech and download LTSpice. Many of their SMPS parts have example circuits that might be applicable to what you want to do. You will be able to simulate many SMPS circuits. But you will have to invest some OF YOUR TIME into it.
As someone else pointed out, your specification is incomplete as well.
Old 15th November 2009, 03:27 PM   #5
ikoflexer's Avatar
50A shunt regulator? Sounds crazy, but I think it can be done. You'd need enormous heat dissipation, and paralleling lots of mosfets. Otherwise, no problems. Many circuits will work, in theory, but to make it work in practice it's a another matter.
Shunt reg latest:positive rail revision 5k
negative rail revision 5d and new: E-MU_0404_USB_mod_wiki
Old 16th November 2009, 02:36 AM   #6
kroto's Avatar
Hi stoc005,
I'm not about buying PS, but learning how to design a shunt reg PS with MOSFET as the pass transistor, or the short-circuit protection
Old 16th November 2009, 02:42 AM   #7
kroto's Avatar
Helo ikoflexer,
ha ha,,, yes it is seems crazy, but thats is what I want to "learn".
Would you like to help me on these?
Old 16th November 2009, 09:12 AM   #8
why a mosfet? and in a TO-220 package? with that much heat dissipation, TO-220 devices won't help. you need ones in big TO-3 or TOP-3 cases to handle the power dissipation.
there are a lot of circuits online using transistors boosting the current capability of LM317 regulators...
Old 16th November 2009, 05:28 PM   #9
kroto's Avatar
With these (IRFZ44) mosfet, I've got the benefit of the compact size of TO-220, big drain current, cheap, rugged device (I think).
dissipation won't much if the Vin isn't too high.
if use BJT, I've know already how they work...
so? how?
Old 16th November 2009, 06:46 PM   #10
russo is online now russo
Dont know if i'm wrong, but you will need to dissipate 13,8v*50A=690watts, thats something
Thread Tools
IRFZ44's in orion 250 SS64 Car Audio 10 1st May 2009 12:12 AM
Is there a difference in a IRFZ44 and a IRFZ44N? Itsme Car Audio 7 5th November 2007 11:33 PM
irfz44 rodolfo Solid State 9 18th April 2005 07:31 AM
how much power can i get fro IRFZ44? Astro Power Solid State 26 4th February 2005 01:12 PM
Aleph With IRFZ44 Jay Pass Labs 7 24th February 2003 09:59 AM
Page generated in 0.10548902 seconds (82.91% PHP - 17.09% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
