Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th November 2009, 12:44 AM   #11
Enzo is offline Enzo  United States
I suspect he won;t be dropping the entire 13.8v ACROSS the transistor.
Old 17th November 2009, 10:04 AM   #12
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
Default Pd
I think that will be:
15*1,414= 21V (assuming the V_ripple not high)
Pd = Vin-Vreg*Iout
Pd = 21 - 13,8 * 50 (max)
Pd = 360W.
but how to use MosFET (HEXFET)?
_@ö
sue
Old 18th November 2009, 07:35 AM   #13
I was being academic. 690 watts or 360 watts, how do you intend to dissipate all that power from one little TO220 transistor?
Old 18th November 2009, 07:59 AM   #14
kroto's Avatar
Default parallel
paralleling of course, HEXFET is more rugged than BJT isn't?
so Pd max of 35W/pcs I think that was suitable.
360/35 = 10,28 or 10 pcs.
_@ö
sue
Old 18th November 2009, 02:56 PM   #15
star882 is offline star882  United States
star882's Avatar
Make a buck converter and you'll only need to use 2-3.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 18th November 2009, 03:11 PM   #16
wg_ski is offline wg_ski  United States
Pd = Vin-Vreg*Iout
Pd = 360W.
At those current levels, a 15-0-15 trafo will give you closer to 15V DC out. Unloaded it will be 21. Dissipation will be significantly less, but still it would be a problem. I'd be more worried about a linear regulator dropping out than anything else. Star's idea of the buck converter is probably the best way to go about regulating this.
IRFZ44's in orion 250 SS64 Car Audio 10 1st May 2009 01:12 AM
Is there a difference in a IRFZ44 and a IRFZ44N? Itsme Car Audio 7 6th November 2007 12:33 AM
irfz44 rodolfo Solid State 9 18th April 2005 08:31 AM
how much power can i get fro IRFZ44? Astro Power Solid State 26 4th February 2005 02:12 PM
Aleph With IRFZ44 Jay Pass Labs 7 24th February 2003 10:59 AM
Page generated in 0.09264 seconds (71.67% PHP - 28.33% MySQL) with 10 queries
