Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th November 2009, 04:45 PM   #1
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Default Transfer Loop Measurement of the power supply
YouTube - Transfer Loop Measurement of the power supply
What do you think, will somebody try this?
Old 18th November 2009, 09:00 PM   #2
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Hi Luca,
Yes this method works... I use this way (but with a network analyzer) to measure the loop in e.g buck converters.
\\\Jens
Old 18th November 2009, 09:18 PM   #3
luka's Avatar
is that trafo really normal, 50-60Hz type, or is it pulse or some other type of trafo?
Old 18th November 2009, 09:36 PM   #4
I use a small signal transformer, like e.g something from a single ended to ballanced LF converter. It does not have to be big at all.
What are you working on?
\\\Jens
Old 18th November 2009, 10:26 PM   #5
luka's Avatar
half bridge, slowly need to get the "feel" for feedback and current limiting, so new version will be in order. And if I do this, why not do it right, its about time for me
Old 21st November 2009, 04:58 PM   #6
If you want to, I suggest you start with a buck converter.
You can make the loop simulation/calculation relativly simple, and verify results by measurements.
I am not an expert, but I will be able to help you with the simulations/calculations.
Warm regards
\\\Jens
Old 21st November 2009, 07:44 PM   #7
luka's Avatar
I'll keep this in mind, but for now, I need to finish 4ch car amp, that will replace my "old" AB amp
But if I ask, why buck? feedback is feedback and should work on any type of converter, right?
Old 21st November 2009, 07:51 PM   #8
The Buck converter is the easiest to make a model of... and it has few part to blow if you insert too much signal in the loop while trying to measure
Old 21st November 2009, 07:56 PM   #9
syn08 is offline syn08  Canada
That's what I'm using, works a treat.
Old 6th December 2009, 08:06 PM   #10
hello...
i guess another paper on the same lines from national.
Loop gain measurement in pspice enzo88 Solid State 9 5th September 2011 04:17 PM
Open Loop Gain Measurement? Fotios Need Help! fotios Solid State 21 22nd April 2008 01:02 AM
Current loop based link signal transfer PMA Solid State 12 23rd June 2005 04:46 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 07:46 PM
Electrical transfer function measurement Thomas B Multi-Way 4 12th March 2003 05:04 AM
Page generated in 0.09862 seconds (80.41% PHP - 19.59% MySQL) with 11 queries
