Go Back   Home > Forums > Amplifiers > Power Supplies
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 12th November 2009, 11:08 PM   #1
Default Need info on CL-100 inrush current limiter
Can anyone here give me the specs of this inrush limiter? I've looked all over the net and found nothing on it at all. Looks just like any other GE inrush limiter... It does exist as I have one sitting in front of me on the desk. If I knew the specs I could match it to something close enough...
Thanks,
Mark
Old 13th November 2009, 12:57 AM   #2
As a GE number CL-100 is obsolete. If you look here the 101 is linked as a possible alternative but if you go to the linked page and look at the spec sheet you'll see that the CL-90, 101, and 110 are quite different , all three of which the DigiKey page for CL-100 lists as possible alternatives.
If it were me I'd go here and pick out something that actually matched the application . Digikey sells them all and if you want to talk over what's best for the app the engineer at Ametherm is very helpful.
Old 13th November 2009, 02:04 AM   #3
Thanks for the tip. I was trying to find out the specs of the original part so I could cross it to something usable. I'm also waiting for the manufacturers schematic comming from Italy (IREM). Orignally it had some similar European made part equivelent a CL-100 in there... Appears to be one in series with each of the capacitors... 4 in total.
Mark
Thread Tools
inrush current limiter! lanchile Chip Amps 7 2nd February 2009 09:20 PM
inrush current limiter circuit Holger Barske Elektor 12 14th October 2006 10:34 PM
NTC Inrush limiter - need info blmn Power Supplies 0 11th April 2006 03:20 AM
Inrush current limiter? roger-k Pass Labs 4 19th February 2006 07:42 PM
CL-60 Inrush Current Limiter ljozsef Pass Labs 8 11th February 2004 09:40 PM
Page generated in 0.07216406 seconds (68.29% PHP - 31.71% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
