Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th November 2009, 02:33 AM   #1
Send a message via AIM to Spasticteapot
Default I need a big current regulator.
I need a current regulator capable of at least 8A at 12 volts. Efficiency, noise, and precision aren't a big deal, as this is for a simple electroplating project. A simple design would be a plus. Any tips?
Old 12th November 2009, 04:09 AM   #2
jackinnj's Avatar
If you want to pay the shipping I have a couple of electroplating supplies in the garage. Systron Donner "Trygon" -- will do 16-19 V, probably 55 amps. I got 'em from NASA in Alabama -- they weigh about 70# each.
Old 12th November 2009, 04:20 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
You can try something like this,
A buck converter is also fairly easy to put together, though 8A is a little steep for something based on, say, MC34063.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 12th November 2009, 02:01 PM   #4
jackinnj's Avatar
One other idea - ham radio transceiver power supplies 13.8V out and beaucoup amps --
Old 12th November 2009, 05:31 PM   #5
I wish I could afford the shipping!
Old 12th November 2009, 06:13 PM   #6
jackinnj's Avatar
i could sneak 'em on a Schneider Truck.
Old 12th November 2009, 10:10 PM   #7
Seriously?
Old 13th November 2009, 09:05 AM   #8
dangus is offline dangus  Canada
It can probably be done with one or two transistors... take a look in The Art Of Electronics. Or use that op-amp CCS circuit with a suitably large power transistor, maybe a Darlington.
An old car battery charger would be a good donor for a transformer and other bits. Maybe the voltage regulator (assuming it had one) could be altered for current limiting instead.
Old 13th November 2009, 10:16 AM   #9
h_a is offline h_a  Europe
h_a's Avatar
You could parallel 2x LT1083 (with common sensing, see datasheet).
Of course you would have to make sure that low dropout is kept.
Have fun, Hannes
PS: a single LT1083 goes up to 7.5A.
Old 14th November 2009, 11:24 PM   #10
gootee is offline gootee  United States
gootee's Avatar
I guess there are lots of ways to do it, if you already have a big honkin' DC voltage supply.
If you wanted an actual bi-polar current source and needed to be able to control the current, or modulate it etc, you could use something like a Howland Current Pump opamp circuit, with any kind of power amplifier as a 'booster' amp, right at the opamp's output (inside the feedback loops). The booster amp could be transistor or chipamp based, for example. But I'm sure there are much simpler ways of doing it, for just a constant, single-polarity DC current.
You should be able to use the same type of idea (booster amp or high-current pass device) with other low-power current-regulator circuits. An opamp and a MOSFET (and a resistor or two) should do it. Some of National.com's and others' Application Notes probably have simple circuits for things like that. Linear.com has AN18 and AN84f, for example. Apexmicrotech.com's ANs 13 and 14 might be useful. National's AN-20, AN-31, and AN-272 might be useful, to give you some ideas. Do some searches.
So you need a big honkin' DC supply.
You could try getting one from a place like jackinnj did, by searching at Government Surplus Auctions at Government Liquidation . The FSC code (in Advanced Search, there) would be 6130. But they might be listed with the wrong code, or something. Best bet is probably to just look at everything at warehouses near you, checking the details for each lot. One used to be able to get several pallets of nice, big DC supplies, there, for the minimum bid. But I haven't followed it for "a while".
Or just slap one together from spare parts.
Need a CRD E-102 (current regulator diode) ostie01 Parts 2 10th August 2006 10:13 PM
voltage current regulator ErikdeBest Tubes / Valves 0 15th June 2006 09:23 PM
ALW Regulator Current Limit? fmak Solid State 7 27th January 2006 09:38 AM
LM317 current regulator Bas Horneman Tubes / Valves 22 17th January 2003 11:25 PM
Using Ixys current regulator as current sink. G Solid State 3 16th November 2002 11:23 AM
Page generated in 0.10280 seconds (81.12% PHP - 18.88% MySQL) with 10 queries
