Can I make a single 800W PSU by connecting 2xUcD supply STs, rated 400W each, in parallel?. What are the consequences? Also, can I add capacitance by adding to or replacing the 10,000uF caps? Any additional mods required for these changes?
I can't seem to get an answer..proj on hold with this.. Thanks in advance if u can help |
#2 |
I asked Hypex, their reply confirmed it's possible. Maybe I'm the only one who didn't know this already..
Summary points: -it should be possible to parallel two UcD Supply STs -each UcD400 module needs only 4700uF (comment: I think this applies to only 8Ohm loads) -when driving an 8Ohm load, the output power will be limited to about 260W for a UcD400 (one TR501 fine for two). Two TR501 toroids required for 4xUcD400 at full potential (comment: and 2xUcD Supply ST as paralleling toroids into one device is not recommended!) -you can add more capacitance to the supply ST, but it's not necessary if each supply ST module is used with 8Ohm loads and up to 800W worth of UcD amp modules (e,g, 2xUcD400 = 800) -when using two TR501 you only need one softstart module (probably obvious..) Last edited by avrg_andy; 12th November 2009 at 11:39 AM. |
#3 |
Good work! Thanks for publishing your work for the benefits of others and I appreciate your hundreds and hundreds of hours spent on getting it to this stage. I am confident that it will sound great and am giving it a go.
| paralleling computer power supply outputs: can they be connected in parallel... | jarthel | Parts | 4 | 5th March 2009 12:03 AM |
| HYPEX Parts F/S! HG Mono Power Supplies, Soft Start, TR501A Transformers! | Socrates428 | Swap Meet | 0 | 27th April 2008 02:30 AM |
| Parallel-ing Switching Power Supplies | JohnT_diy | Power Supplies | 11 | 7th July 2007 05:00 PM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 04:55 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 05:21 AM |
| Page generated in 0.08375 seconds (66.93% PHP - 33.07% MySQL) with 10 queries |
