Is there an easy path to change the frequency of the mains? My amplifiers do work on 220V/50Hz mains where I reside, but it really is designed for 60Hz operation, according to the designer. Thanks in advance for all your inputs.
#2 |
no.
the hardware to change from 50Hz to 60Hz will be expensive.
regards Andrew T. |
#3 |
also I think you could use 50Hz amp on 60Hz, not a big change IF the voltage will still be 220v
#4 |
You can use a special inverter or cycloconverter, but you don't need one. Modern power supples convert the incoming AC into DC before doing anything, so frequency doesn't matter much.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#5 |
IMHO ...I don't believe it to be a big deal...
When you design transformers you typically make sure it is good for both 50 and 60 HZ.. With 50 Hz the flux denisty will go up about 825 Gauss with respect to 60 Hz operation.... So any descent transformer for quality equipment should be designed with conservative core losses in the first place.... another 825 gauss will give a bit more core loss and a little more heat, but should not be significant... If another 825 Gauss put the transformer in trouble, then the steel was being pushed too hard in the first place for 60 Hz... As for voltage ripple after rectification, you now have 100Hz to filter instead of 120Hz.... This is roughly 6dB less filtering than at 120Hz..This may or may not be a problem....Added capacitance can help, but watch out for peak current with reduced diode conduction angle... Chris |
#6 |
You will have absolutely no problem going from 50 to 60Hz at the same voltage. The other way around could make things slightly warmer.
#7 |
If the voltage regulators become stressed at lower frequencies, the input capacitors are way too small.
#8 |
star882
Transformer saturation could be a problem, if a 60 Hz transformer is run at 50 Hz and the line voltage is at it's upper limit. Rick |
#9 |
I have not seen very many mains frequency transformers in modern equipment. Switchers are now the power supply of choice.
#10 |
Are SMPS used in audio equipment?
| Mains voltage change for Sonic Frontiers SFS80 ? | Joschl | Tubes / Valves | 0 | 8th January 2009 01:02 PM |
| Mains frequency variation | Circlotron | Everything Else | 11 | 3rd March 2008 11:49 AM |
| Why is mains frequency so low? | Nixie | Parts | 3 | 29th November 2006 12:13 PM |
| Change in frequency mains | Raka | Analog Line Level | 49 | 17th January 2006 05:59 PM |
| Mains frequency stability | Prune | Parts | 10 | 26th November 2004 06:09 PM |
| Page generated in 0.57976 seconds (16.58% PHP - 83.42% MySQL) with 10 queries |
