Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th November 2009, 10:10 PM   #11
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by sawreyrw View Post
Are SMPS used in audio equipment?
some have it, but most really high end equipment doesn't really use it. I'm not a fan
Old 9th November 2009, 10:27 PM   #12
It seems to be mainly used in pro gear where the weight reduction is serious.
Old 9th November 2009, 10:34 PM   #13
Banned
I remember getting hold of a qsc schematic once, DAM those are light amplifiers but tons of welding power
J'
Old 9th November 2009, 10:48 PM   #14
Any given power transformer will perform a bit worse at 50 Hz, even if designed for it. The name of the transformer game is cost, so they try to use the cheapest transformer steel and as little of it as possible. If your power transformer isn't producing mechanical hum, and if it isn't running excessively warm, don't worry about it. The cure is worse than the disease. You'd have to get something like a California Instruments, Invertron or Elgar voltage/frequency converter. (can't remember who makes what) The cost would be prohibitive and they're often noisy. Most audio equipment is way over designed when you consider the real average power requirements, so both the tranny and filter caps are probably fine for 50 Hz. OTOH, I used to have an Integral System 100W/ch amp with a transformer that hummed and ran hot enough to cook on even at 60 Hz. Just a very low quality part.
I used to be an audiophool like you but then I took an arrow to the knee.
Mains voltage change for Sonic Frontiers SFS80 ? Joschl Tubes / Valves 0 8th January 2009 12:02 PM
Mains frequency variation Circlotron Everything Else 11 3rd March 2008 10:49 AM
Why is mains frequency so low? Nixie Parts 3 29th November 2006 11:13 AM
Change in frequency mains Raka Analog Line Level 49 17th January 2006 04:59 PM
Mains frequency stability Prune Parts 10 26th November 2004 05:09 PM
Page generated in 0.07624 seconds (69.33% PHP - 30.67% MySQL) with 10 queries
