Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th November 2009, 08:55 PM   #1
Default Testing N-Channel
I am working on a switch mode power supply. This a very basic question.
IC is STMicro B20NM50. Every combination of leads give no continuity. I am hoping someone will reinforce my conclusion that this IC is defective.
Old 4th November 2009, 09:14 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This is STB20NM50
http://www.stmicro.fr/stonline/produ.../stp20nm50.pdf
Pinout is standard G D S. At least the D-S diode should show up when looking with a multimeter. Gate should appear open with respect to the other two terminals when using the diode test function. Finally, when a few volts are applied from G to S, a low resistance should appear between D and S.
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th November 2009, 09:27 PM   #3
Default N channel
Wide open with multimeter on all pins in both directions.
Old 4th November 2009, 10:12 PM   #4
Eva's Avatar
It's very likely to be blown, but they usually fail shorted D-S and/or G-S (or G-D when S internal bonding wire blows).
If you are not used to checking MOSFET try with any other N-ch known to be ok (or blown too) and see if they behave as I explained.
Old 5th November 2009, 04:36 AM   #5
star882 is offline star882  United States
star882's Avatar
A normal multimeter cannot be used to test a MOSFET.
One easy tester is to connect a car light bulb in series with the positive side of a 12v power supply. Connect positive to drain and negative to source for a N channel MOSFET. Turn it on and touch the gate and source terminals at the same time, making sure not to touch the drain. The bulb should not light up. (If it does, the MOSFET is shorted - most common failure mode or the connections are incorrect.) Then touch the gate and the positive side of the power supply at the same time. The bulb should light up. Let go and the bulb should remain on for at least a few seconds.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 5th November 2009, 06:17 AM   #6
I like that method. Sounds cool. Unfortunately, I used diode test on a different meter along with diagram of N channel and found the it is ok. Guess I have to keep looking. looks like my problem is going to be in surface mount components. Now I need glasses!
Thanks for help.
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 08:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 06:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 12:10 PM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 07:41 AM
Help quick! 4 Channel > 2 Channel? zmoz Car Audio 3 5th July 2003 09:48 PM
Page generated in 0.08872 seconds (75.01% PHP - 24.99% MySQL) with 10 queries
