Posted this question in the F5 thread in the PASS section. But after thinking about it, I thought it might be a better question in the power supply section:
I am using some Hammond 159ZL chokes for the CLC power supply. With air core inductors I have read that the inductors should be mounted as far away from each other as possible (and/or at 90deg angles to each other) to minimize magnetic coupling. When using the iron core Hammond chokes, is mounting proximity still an issue? Or, is it not that significant since more of the magnetic field will be concentrated atthe iron core? Thanks, Steve |
#2 |
It won't be as significant but it shouldn't hurt.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
Thanks Star,
I will try and keep them as far apart as possible. But, I am getting a little tight on space in the case. Steve |
| choke for the power supply | jarthel | Pass Labs | 44 | 2nd July 2007 11:23 AM |
| Effect of supply bypass positioning. | Arx | Chip Amps | 10 | 10th June 2007 09:13 PM |
| Aleph P 1.7 pwr. supply choke clc | Shaun Perez 2 | Pass Labs | 5 | 9th November 2005 02:17 AM |
| Choke For Supply B+ Diy | TRAN TUAN KHANH | Tubes / Valves | 8 | 25th July 2005 11:13 PM |
| Page generated in 0.07272 seconds (67.12% PHP - 32.88% MySQL) with 10 queries |
