Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd November 2009, 05:55 PM   #1
Default Tube mic Power supply
I want to modify my tube mic power supply. It is reccommended to replace
1N4761 with 1N4758 to reduce capsule voltage from 196 volts to 112 volts. The thing is that the diodes in mine are 1N4007 not 1N4761. I don't know my diode values.
Will 1N4758 reduce my voltage?
Old 3rd November 2009, 05:19 AM   #2
Enzo is offline Enzo  United States
What mic, what supply, can you post or link to schematics? Without a context, or recognizing those numbers as part of something specific, we are in the dark here.
1N4007 are rectifiers, while the 1N47xx are zener diodes. It would not be unusual at all to find both types in a power supply. The 1N4007s are used to make the raw DC for the circuits, and the 1N47xx in the voltage regulator circuit.
If you don't know what a particular diode is rated for, just enter the part number into google and a link to a data sheet will emerge. or look the part up in Mouser, and click on the data sheet link on the line with each part. Usually one data sheet covers the entire sequence, so you ought to find a chart with ALL the 1N47xx series listed in order of voltage. Of course 1N4007 will be on a separate sheet.
Tube power supply duderduderini Tubes / Valves 1 9th December 2008 05:33 AM
tube power supply MiiB Tubes / Valves 10 2nd March 2008 02:52 PM
WTB:power supply for tube preamp dariusku Swap Meet 0 18th September 2006 07:04 PM
Tube power supply for TT Miniwatt Analogue Source 1 8th March 2005 07:49 PM
Power Supply and VR tube help! AudioGeek Tubes / Valves 24 28th February 2004 01:16 AM
Page generated in 0.10985 seconds (60.08% PHP - 39.92% MySQL) with 10 queries
