Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th October 2009, 11:56 PM   #1
355F1 is offline 355F1  United States
Smile Reducing fan speed
Hello,
My name is Orazio and, even though I have been a member for quite a while, this is my first post.
I have an old Dayton boxer fan [110V, .16A and 13W]. I would like to half the fan speed by reducing the voltage to, let's say 50V and, according to my calculation, I need a 4.3 watt resistor.
Any idea where to get just one 110V 4.3w resistor?
Thank you very much in advance.
Orazio
Old 30th October 2009, 12:10 AM   #2
Did it Himself
richie00boy's Avatar
You've not quite got it right, resistors are specified in ohms not volts.
Fan equivalent resistance R = V / I = 110/0.16=687.5 ohms
Therefore if you put a 687.5 ohm resistor in series with the fan you will halve the voltage the fan sees.
With approx 55 volts across the resistor it will dissipate P = V^2 / R = (55x55)/687.5=4.4 watts
The closest practical component is 680 ohms, 6 watts. Depending on the fan though it may not necessarily turn at half speed, you may have to experiment to find a suitable resistor to give you the speed you require.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 30th October 2009, 12:34 AM   #3
Sorry, my mistake, I should have written 825 ohms and 4.3 watts per the following table:
Original fan voltage: 110V
Original fan current: 0.16A
V=IR (Ohm's Law), so 110 = 0.16R => R = 110 / 0.16 = 687.5
Fan resistance: 687.5 Ohms
Target voltage: 50V
V=IR (Ohm's Law), so 50 = 687.5I => I = 50 / 687.5 = 0.073
Target current: 0.073A
Voltage drop across resistor: 110V - 50V = 60V
V=IR (Ohm's Law), so 60 = 0.073R => R = 60 / 0.073 = 825
Target resistance: 825 Ohms
Power dissipated by resistor: 60V * 0.073A = 4.364W
Thanks a lot.
Orazio
Old 30th October 2009, 12:41 AM   #4
star882 is offline star882  United States
star882's Avatar
You cannot reduce the speed of an induction motor by decreasing the voltage.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 30th October 2009, 01:12 AM   #5
I could use a dimmer but it is not very convenient and wanted to simplify things.
Old 30th October 2009, 01:52 AM   #6
boywonder's Avatar
I've decreased the speed of my CPU fans on my computers with resistors, are they induction motors? They are certainly brushless. It works great.
Old 30th October 2009, 03:04 AM   #7
nigelwright7557's Avatar
I have used dropper resistors on PC fans too.
I use the running current of the fans to determine the resitor required.
I use two 12 volts fans in series with a resistor dropped from 60 volts.
It does need a 10 watt resistor tho.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 30th October 2009, 04:06 AM   #8
star882's Avatar
Brushless DC fans are basically induction motors with built in inverters, but the frequency changes with voltage.
Old 30th October 2009, 05:05 AM   #9
cbdb is offline cbdb  Canada
If its a 110v ac induction motor with a speed thats 3600 rpm (or multiple) than its speed is based on the 60 hz (60x60=3600 rpm)of the line voltage, adding a resistor will probably increase the current the motor draws, keeping the speed approximately the same. A dimmer might work.
Old 30th October 2009, 12:54 PM   #10
Chaps,
I have two of these fans, NOS - 25 yr old, cast iron, USA made - Dayton square AC axial fans, air flow 75 CFM, voltage rating @ 50/60 Hz 115, 4 11/16" square, 1 1/2" depth. Current rating is 0.16 Amp, power rating is 13W, speed 1800 RPM.
Orazio
reducing voltage rtill Solid State 28 16th January 2009 02:45 PM
Reducing LED intensity qguy Everything Else 8 8th February 2008 01:04 AM
Reducing midrange qguy Multi-Way 5 21st October 2006 07:15 AM
reducing output Lostcause Power Supplies 4 7th September 2006 10:50 PM
reducing hum mrjcfreak Tubes / Valves 5 19th July 2004 03:26 PM
Page generated in 0.10288 seconds (77.15% PHP - 22.85% MySQL) with 10 queries
