Hi guys
![]() I found an old smps in a blaupunkt car amplifier with output voltage +27 0 -27 Volts. I would like to tweak to have a better power supply: I already change the old capacitors at primary and secondary: was: 4x 470uf for primary now: 4x 1000uf was: 2x3300uf for secondary now: 2x10000uf I also change the two rectifier diodes by 1 C2522 and 1 C2526 support more output current: But i would like to change the four mos-fet Buz103Al with four IRFZ46N because the ouput current is better for the IRFZ46N mosfet Do you think it's a good idea? But before any change on the power supply i found a resistor very hot i don't know why it's strange ![]() This is a photos of my power supply with resistor who are hot. Is it a resistor to compensate the temperature? ![]() ![]() ![]() ps: for you américan do you think my english is very bad or it's ok ![]() Sorry for this stupid question Thanks for your help ![]()
#2 |
Hi
![]() Nobody can help me please? ![]() For the moment the first problem is the resistor who is hot but the power supply works good ![]() If you have an idea about the heat release by the resistor ?? Thanks a lot in advance
#3 |
The resistors look like 3-5 watt units and can get pretty warm without issue, and since they have not turned brown, they are most likely within spec. As for the IRFZ's, Fosgate uses them in quite a few of their car amps.
#4 |
Hi jerluwoo
![]() Thanks a lot for your help ![]() So i'm not obliged to change the resistor ? For the IRFZ i'll mount it on the power supply Thanks
| audio SMPS startup | Pierre | Power Supplies | 34 | 31st March 2011 05:31 PM |
| 2 IC SMPS for car audio, how stupid is this? | MrPerfectionest | Power Supplies | 1 | 16th March 2009 01:59 AM |
| gate resistors for irfz46n replacements | PM650 | Car Audio | 1 | 9th December 2007 09:02 PM |
| Upgrading My SMPS For Audio Use | dantwomey | Power Supplies | 0 | 11th January 2007 01:42 PM |
| Car audio SMPS transformers | Toddy Audio | Swap Meet | 6 | 13th August 2004 04:39 PM |
| Page generated in 0.09711 seconds (64.96% PHP - 35.04% MySQL) with 10 queries |
