I have been reading this interesting and, I believe, well known article from TNT: Solid State Power Amplifier Supply Part 2 and I am struggling to figure our which is the transformer's secondary windings voltage recommended by the author under his example. Is it 20V?. He mentions 20 Vrms but I am not sure what he is taking about. Your help will be greatly appreciated. Regards Antonio |
#2 |
He is talking about a 50W at 8 ohms amp. That is where the 20V RMS comes from. You would need two transformers (for the example he gives) with a secondary voltage of roughly 24V each.
#3 |
Steve,
Thanks for your prompt reply. Yes, I am planning to use two separate transformers. Since my speakers' impedance is 6 Ohms (Jordan JX92S and Aurum Cantus 2Si), if I understand correctly I would be fine with 22V (or maybe 20V?) secondaries. Thanks again Antonio |
#4 |
Yes, you can use those voltages. The 20V transformer will give you about 46W at 6 ohms. 22V will give 54W at 6 ohms.
#5 | |
![]() What would you choose in this case- 20V or 22V- if your priority was a better sound- not necessarily high volume per se? Thanks a lot. |
#6 |
You are not likely to hear any difference. I would let price and availability be the deciding factor.
| Battery vs Conventional PSUs | Gopher | Solid State | 43 | 24th April 2007 07:57 AM |
| Can one transformer supply two psus? | xcortes | Chip Amps | 3 | 3rd May 2006 12:52 AM |
| 2 PSUs or DIY? | DragonMaster | Power Supplies | 15 | 19th April 2006 03:00 PM |
| Cascode PSUs | mcai7et2 | Solid State | 3 | 19th February 2004 11:44 AM |
| inductors for PSUs | uli | Pass Labs | 0 | 26th January 2003 08:36 AM |
| Page generated in 0.09183 seconds (70.29% PHP - 29.71% MySQL) with 10 queries |
