Go Back   Home > Forums > Amplifiers > Power Supplies
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 26th October 2009, 12:04 PM   #1
matherp is offline matherp
Default Class D: power supply regulated or not?
Hi all
Apologies if this has been answered but couldn't find anything in the searches.
I'm building a power supply for one of the Sure 2 * 100W class D (T) amps. I've got a nice 300VA toroidal transformer but don't know whether to regulate the output with a pair of LM338Ks or just smooth it.
Basic circuit is full wave rectification; thermistor surge protection; 0.1ohm, 2 * 22000uF capacitor RC smoothing,
Then the question is whether to regulate the output using the LM338s or just put another big capacitor after the RC filter.
What are the pros and cons?
Peter
Old 26th October 2009, 02:39 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Does it not seem strange to you to suggest linear regulation for a class D amplifier? Why not cut out class D altogether and use an LM3886? Or cut out linear altogether and use buck regulator(s)? Or cut both out and use a better amp, one with high PSRR?
What is the PSRR spec on the amp? If it's 80dB or more, leave it be.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 27th October 2009, 12:16 AM   #3
star882 is offline star882
star882's Avatar
What does the datasheet say? The logic will almost always need regulated power, but the power stages might be able to not use regulation. If it's SE, it most likely would require regulation as it depends on a regulated voltage for the Vcc/2 to remain stable. BTL can sometimes do without regulation, however.
It's silly to not use regulation nowadays, however. Just build a buck converter. It might even be possible to use dynamic supply voltage to increase resolution at low volume settings.
Get OpenOffice.org!
Thread Tools
Best regulated power supply. JC951t Digital Source 20 14th November 2007 09:04 PM
regulated power supply adason Swap Meet 1 11th December 2005 06:32 PM
BPA Regulated Power Supply h_andree Chip Amps 11 26th April 2005 09:30 PM
regulated power supply yugaaa Solid State 17 28th January 2003 02:39 PM
regulated power supply yugaaa Solid State 3 17th June 2002 06:22 PM
Page generated in 0.06812096 seconds (71.39% PHP - 28.61% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
