Hi! I have a power supply that delivers +-38V. The problem is that the amplifier im using it for is rated +-36V max. So, could i use diodes to limit the voltage on the PS? And how?
Thanks. |
#2 |
Modify the voltage regulation to output a lower voltage.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
Its really the transformer that delivers too high voltage, are you sure i can drop the voltage modifying the rectifier-stage?
#4 |
Add a voltage regulator, then. Or add an autotransformer to step down the input a little bit.
#5 |
If you could send me a link to the components you are refering to, that would be really great!
#6 |
Passive Aggressive
You could use an LM338 for instance, but remember you must be able to drop the full current. If you are going for 36V probably you run the risk of large current and then the voltage regulators that could handle it get expensive.
Another thing you can do is to add series resistance to get a voltage drop in your PSU. Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 24th April 2011 12:48 AM |
| Power Supply Voltage For 5881/6L6 Amp | simonmurr | Tubes / Valves | 2 | 1st December 2009 06:16 PM |
| Comprimize of power supply voltage | cm961 | Chip Amps | 3 | 16th June 2003 09:35 PM |
| No Load Voltage on Zen V4 Power Supply | vsr123 | Pass Labs | 13 | 5th May 2003 05:10 PM |
| help! power supply voltage issue | jlg4104 | Tubes / Valves | 15 | 2nd December 2002 07:35 PM |
| Page generated in 0.09016 seconds (72.98% PHP - 27.02% MySQL) with 10 queries |
