Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd October 2009, 09:05 AM   #1
Tripmaster's Avatar
Default SMPS Fault
Hi
Please excuse this non-audio related question.
I have just replaced a potentiality faulty reservoir cap in an LCD display. I hooked up a light bulb tester and the bulb glows brightly, and flickers in time with the switching power supply.
I didn't use the bulb tester before changing the cap so I am unsure if the bulb would have flashed in the same way.
EDAC EP2200
Any help will be appreciated?
Richard
Old 23rd October 2009, 09:26 AM   #2
Hurtig is offline Hurtig  Denmark
Be carefull!! SMPS is not for dummies Not that I say that you are...
They often involve quite large high voltage capacitors, that will tickle quite hard....
Old 23rd October 2009, 09:27 AM   #3
Old 23rd October 2009, 09:30 AM   #4
Tripmaster's Avatar
Originally Posted by Hurtig View Post
Be carefull!! SMPS is not for dummies hard....
You are not too far from the truth
Yes it's a 150uf 450v cap!
Old 27th November 2009, 02:20 PM   #5
Tripmaster's Avatar
Hi there
It turned out to be the inverter.
Thanks for your help!
Richard
My photostream: http://www.flickr.com/photos/59839778@N04/
Old 27th November 2009, 05:45 PM   #6
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
cool!
Old 21st October 2011, 03:57 PM   #7
Tripmaster's Avatar
Wow, almost two years to the day of my last post my second display panel has failed. I swapped out a few of the components from the original monitor to locate the faulty part, and this time its the smps. An identical supply is pictured in the first post.
I noticed a pulsating whine when trying to power up the screen, and think it was coming from the smps. I tried cycling the power quickly a couple of times and the screen would display briefly. When the screen first failed it blew a fuse, this was replaced and it didn't happen again.
Any suggestions?
Richard
Richard
Old 22nd October 2011, 01:18 PM   #8
Send a message via Yahoo to Th3 uN1Qu3
Some pics of the power supply and part numbers on the ICs, mosfets and diodes please. I assume you do have a multimeter. Use a 100W bulb in series with this supply, that looks like a big monitor.
"Audio grade" components simply means that they failed at a more critical job.
Pre amp fault Addolff Parts 4 6th January 2008 02:55 PM
cd6000 fault goodlife Digital Source 11 28th April 2006 07:31 PM
sorted out amp fault leander Solid State 0 22nd September 2005 07:00 AM
Buffer Fault pete.a Chip Amps 17 8th September 2004 09:10 PM
alpha 5 Fault paulcurrie Digital Source 2 13th February 2004 12:32 PM
Page generated in 0.09134 seconds (78.29% PHP - 21.71% MySQL) with 10 queries
