Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd October 2009, 08:09 PM   #1
Default Split +/-12V Phono preamp Power Supply
My Audio Alchemy VITB power supply (+/-12V) has died and I'm having a very difficult time finding a replacement for it. Currently, I'm tempted to use the +/-12V rails from a spare computer power supply - but I think it may sound too noisy. I suppose I could also use two single-ended 12V supplies (tying the (-) rails together and calling that ground.)
Any better ideas?
thanks
Kofi
Old 22nd October 2009, 09:21 PM   #2
mjf is offline mjf  Austria
hello.
two 12v batteries/akkumulators in series...............
or building a psu with volt regs............like lm317/lm337 or so..........there are some threads in the forums that can help.
greetings...........
Old 22nd October 2009, 09:51 PM   #3
russo is offline russo  Portugal
A computer power supply is single ended, that means that there are no -12V, only +12V and ground, in fact, each molex connector has +12V(yellow), +5V(red wire) and 2 grounds in the middle.
And you cant connect two grounds, or else, you can, but doing that doesn't give you a symmetrical power supply, to have one symmetrical, you must connect the +12V to the ground line of other equal power supply and then the 12v will be +12v, the ground will be -12v and the 12v connected to the ground is your new ground.
But, isn't easier to repair the original power supply?
Old 22nd October 2009, 10:22 PM   #4
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Not sure if you wanted a pre-made PCB or not, but...
New bipolar low-voltage power supply for solid-state projects
Jim J.
Old 22nd October 2009, 10:59 PM   #5
Steerpike's Avatar
Thats only the disc drive connector. The main supply to the processor board caries -12 and +12.
But as pointed out, it will be noisy, it being a switched mode power supply with only the bare necessities of filtering.
Buying two identical +12v supplies & commoning one (+) and one (-) will work perfectly well; or make your own as mentioned with the LM317/337 chips. Or if you are less fussy, simpler versions can be had using the LM7812 and LM7912 regulators - it's very simple.
Steerpike's Toybox
Old 22nd October 2009, 11:11 PM   #6
picowallspeaker's Avatar
Go hollow state .
use two 5Y3 GT , feed them with 5V each , add an LCLC made from 10 H and 100 uF ,Polyester .
A 50 W trasformer would be good for the duty
Note :It is not scientifically demonstrated , but the heavier the better ..
Old 23rd October 2009, 04:28 AM   #7
Originally Posted by picowallspeaker View Post
Go hollow state .
What is "hollow state"? This is a little cryptic; could you elaborate a little?
Kofi
Old 23rd October 2009, 04:53 AM   #8
...to have one symmetrical, you must connect the +12V to the ground line of other equal power supply and then the 12v will be +12v, the ground will be -12v and the 12v connected to the ground is your new ground.
Of course, you're right. What I described would be a parallel connection.
The original was sealed - no civilized way to get in.
Kofi
Old 23rd October 2009, 04:56 AM   #9
Coreyk78's Avatar
I would recommend trying the power supply designed by RJM for the vsps, it's simple and it works very well, I'm listening to it right now.
RJM Audio - Construction Guide
Old 23rd October 2009, 05:25 AM   #10
I don't see anything there that is just a power supply. I need just an unregulated power supply because the VITB has all the regulation inside it.
I'm not averse to building a simple power supply if he has a kit for just that. Does he?
Kofi
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
JLTi phono preamp - upgraded power supply? Kenreau Power Supplies 5 23rd September 2009 07:32 AM
Power supply for 12SL7 phono preamp HawkSpeed Tubes / Valves 28 25th June 2008 04:00 AM
In search of power supply schematic for phono preamp jduffy Tubes / Valves 16 9th April 2007 05:58 PM
Having trouble building a power supply for a phono preamp SideA Solid State 1 4th April 2003 07:34 AM
Page generated in 0.12066 seconds (77.48% PHP - 22.52% MySQL) with 10 queries
