I have 2 capacitor 33000uF/70V and what resistor i have put on capacitor power suplly is 45V ( + and - and GND )
thanks |
#2 |
45v/current rating gives you the resistance to use for full load testing. Such a resistor would likely be big and expensive, so it might be possible to use light bulbs or heating elements as a test load. (Calculate resistance with original voltage^2/original wattage.)
If you want precharge, use 45v/peak current rating for the resistor to limit inrush current. You'll need a relay to bypass the resistor after precharge.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
+-45Vdc sounds like you are using a 32Vac or 33Vac transformer.
You can attach the two 33mF smoothing caps direct to the rectifier without needing a slow charge resistor. I would fit a soft start for the transformer, again a resistor or thermistor with a relay bypass using a 200ms delayed timer.
regards Andrew T. |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 06:10 PM |
| is there a circuit for a power supply to power the differant add on clocks | frank2395 | Digital Source | 1 | 30th June 2005 10:33 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 03:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 02:30 PM |
| Page generated in 0.06958 seconds (71.17% PHP - 28.83% MySQL) with 10 queries |
