Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th October 2009, 02:06 AM   #71
I have now come up with a new idea.
Remote sensing to the local star ground. In this case, the inductance between the PSU and load is eliminated, leaving only the local inductance and resistance on the load board only.
Actually, I now think this may be what Salas in post 61 refers to. Salas, please confirm. Thanks again.
Old 30th October 2009, 02:56 AM   #72
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If you have grounded your ICs to a star on your filter boards plus they receive +/-V symmetrically in layout, I think that a main force/sense scheme is going to be beneficial enough compared to just 3 thick wires.
Old 30th October 2009, 03:40 AM   #73
Salas's Avatar
Originally Posted by Salas View Post
Maybe its Japanese in origin, I think the older that I have seen is the Stax one.
Originally Posted by tvi View Post
As far as I know this is the original patent
Highly stable constant-voltage power source device
US Patent 4366432 Noro, Masao Stax Ind Ltd
James
Old 30th October 2009, 04:38 AM   #74
ikoflexer's Avatar
You were right on the money Salas!
Old 30th October 2009, 09:38 AM   #75
Just a thought, as I have not given it much thought, no doubt that force/sense eliminate the error of the resistance of wires. Does it eliminate the error of the inductance of wires as well???
Old 30th October 2009, 10:24 AM   #76
syn08 is offline syn08  Canada
Yes.
Old 30th October 2009, 11:53 AM   #77
.....The initial CCS current was set to very low ..................
............When I increased the current to 130mA a few minutes later the shunt heatsinks got very hot. I could not touch it for more than a fraction of a second.
Some minutes passed now. The CCS current did not increase but dropped to 102mA and 100mA............ Since the heatsinks are only warm
why are the heatsinks too hot to touch @ 130mA and yet only warm @ 100mA?
There is something you have not told us!!
regards Andrew T.
Old 30th October 2009, 12:01 PM   #78
I am planning on no local decoupling. Local coupling introduces a whole lot of issues with resonance from LCR circuits.
as far as I have seen, all opamp manufacturers specify local decoupling to ensure their opamps meet specification.
regards Andrew T.
Old 30th October 2009, 10:55 PM   #79
I have been down that way many times and have not found an answer yet. I have had 0.1uF, 0.01uF and other value local bypass capacitors on my active EQ/XO board for the NaO speakers designed by John K. I compared many times adding and removing bypass capacitors.
With local bypass, the higher frequency range within the audioband seem to perform better. However, it also adds some strong colourations, exaggeration or brightness to the sound and make the sound really dirty. I suspect that it is due to oscillation but have not had a scope to measure it.
Without local bypass, the sound may be less liquid at higher frequencies, but a lot more "right", "together" and even more detailed.
I tried to use LTSpice to model it. All regulators are inductive at certain high frequency range. For example, around 5uH for the LM317, so I read. Here is a relatively large L. The wire adds L and R. The local bypass is the C. The LCR circuit has to resonant at some point. With the typical output inductance of a 3-terminal reg, and the typical bypass value of 0.01-0.1uF, resonance occurs anywhere from 800kHz to 3MHz, depending on the values. I have also tried adding R in series with the PSU, making it a RC low pass with the R provides damping to the LCR. Yes the resonance peak may be damped but the sound is boring to listen to! It never sounded right to me. I came to a belief that no R should be in series to the PSU (unless it is before the regulator, of course)! When current flows through the R, the voltage developed is an ERROR. Local bypass capacitor is intended to provide a low impedance path. From the Vishay Blue box' datasheets, a 0.1uF has an ESR of 0.03R, a 0.01uF has an ESR of 0.1R. This is still higher than a regulator like the Jung Supereg, Salas v1 and v2.
I am sure I am not the first one to do it without bypass capacitors. In Jung's Supereg 4 part articles, I think in the last article he said that with the Supereg, no local bypass should be used. He even provided a MOD to his circuit so that for those who stubornly insisted on using local bypass could use it without having the resonance.
I guess that if RF does not get into the signal, and I have 1k-68p-1k-68p in front of the input of the circuit, it may have less of a problem.
I understand that most opamp manufacturer datasheets recommend using local bypass capacitors. I read them a lot very carefully and did what they said but have had no luck with audio due to the LCR resonsance. Then I thought. Perhaps most opamps are designed for a wide range of applications, not just audio. In most other high frequency applications, local bypass may be a "MUST". But when the engineers recommend using local bypass, do they refer to audio in their mind? I don't know.
So a regulator of super low impedance of high bandwidth, like the v2, goes a long way to achieve better sonic. I think this is the design philosophy behind the Jung Supereg.
The problem of without bypass, of course, is that the PSU may need to be located right at the circuit (or remote sensing). And this only ensures that there is a low impedance path to the circuit up to, say, 200kHz. Beyond that, the impedance of a regulator rises. If RF gets into the circuit, the high impedance of the PSU may be problematic to the opamp circuit.
No, I have not an answer yet. I am afraid that I have to experiment, which is a very tedious process.
I am humble to listen to what the experts say.
Old 30th October 2009, 10:57 PM   #80
After that event I wondered if I had the current set to 1A instead of 100mA! But it was highly unlikely. It was a mystery for me and I can't think of the reason why. After the second time turn-on there was no problem.
The simplistic Salas low voltage shunt regulator ikoflexer Power Supplies 4802 11th February 2012 01:16 AM
Tube for a shunt voltage regulator jarthel Tubes / Valves 14 26th October 2006 05:19 AM
Page generated in 0.14362 seconds (77.26% PHP - 22.74% MySQL) with 11 queries
