#671 |
stormsonic, I'll make another board for you tonight because I'm sending Salas the two that I just finished.
keantoken, I thought about it, we're going to have problems if you're not setup for soldering at the moment. The current limit needs to be set, probably changed, for a real test. And that involves soldering different resistors. Same goes for the output voltage. I'd like to get the tests done sooner rather than later, to minimize the wait for everybody. Just so that we have no confusion. The pcb boards that I'm sending away for testing are etched by me, manually, using ferric chloride. They are not made by the pcb manufacturer. The cost is high to just order a few pcbs and the wait will be longer. Also, the only real difference between the pcbs that I etch and those from the manufacturer is the mask. The copper layer follows the same dimensions exactly, since I transfer the copper layout using a laser printer. The boards from the manufacturer will look a lot more professional, but functionally they are the same as those etched by me at home. |
#672 |
Thanks for putting so much effort in this, Iko.
#673 |
I was just saying to Salas last night that it's starting to be a bit of a pain, but I hate starting something and not finishing it, so I'll see it through.
It's a given, when we want to squeeze the last bit of performance out of a circuit, it becomes a bit more complex and then it's hard for a lot of people to build it up to spec without a proper PCB. |
#674 | |
For me, I've got plenty of "hobbies" but DIY audio is my favorite and if it wasn't for guy's like you it wouldn't be half as much fun. Big
#675 |
It depends on whether there are components around the resistors that I might damage by repeatedly exposing to very hot air coming from the iron. It will probably work if I get in and out fast, depending on the layout.
- keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#676 |
kt, the board is pretty densely stuffed.
Salas, two boards plus semis are on their way to you. I had to do regular mail because express mail was $56 |
#677 |
diyAudio Chief Moderator
Thanks.
Only regular mail. Special services are not that faster, and there is no rush.
#678 |
For what it's worth, I still have been unable to get this design to simulate without oscillation. I have tried several device models but to no avail. Maybe in this case reality is completely out of sync with simulation.
This is in complete contrast to the Salas reg which simulates very well: 118.PNG And unconditionally stable. |
#679 |
AFAIK, there is a certain tradeoff between between regulation and stability between the Salas and Ikoshunt (or whatever it's called). (In LTSpice it has worked for me)
Since soldering would probably be a problem, go ahead and send my boards to someone else, if you think it's best. Also, have you tried testing Zout vs. frequency in real life? - keantoken
#680 |
Stay tuned.
| The simplistic Salas low voltage shunt regulator | ikoflexer | Power Supplies | 4802 | 11th February 2012 01:16 AM |
| Tube for a shunt voltage regulator | jarthel | Tubes / Valves | 14 | 26th October 2006 05:19 AM |
| Page generated in 0.13103 seconds (74.30% PHP - 25.70% MySQL) with 11 queries |
