#381 | |
Andrew, what do you mean about the cost of the cetoole reg? The reason I don't see hundreds of people interested in this regulator is not the high price, since none has been set. Edit: I should add, there are two ways you can get this regulator for the price of a few coffees: 1) You make your own boards. It's easy. I've done it. It works. I can guide you and help with that. 2) You're at at time in your life that money is very tight. Then let me know privately. Last edited by ikoflexer; 18th December 2009 at 01:46 PM. |
#382 | |
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
#383 |
He he
#384 |
diyAudio Chief Moderator
The current thread's CCT concept works smoothly in many guises. I am in good experience to know it.
#385 |
Salas, you're too nice. But you know what's involved in making these so you speak from experience. If anyone should get something back from the hours on end of work, plus hours on end of customer support, it's you!
So I tried some quotes from pcb fab people and guess what? The cheapest way was to get the boards individually done, not several circuits on one bigger v-scored board. Andrew, are you listening? The difference in price was not large, but with the v-scored boards there is extra work involved in separating the circuits for those who want them separate. So, there goes that myth. |
#386 |
received logic level MOSFETs and assembled new board.
Picture without output cap, oscillations with 88 mV peak-to-peak ![]() Output cap 3.3uF MKP Vishay ![]() Zoomed trace, final version. Output cap 47uF Panasonic FC + bypass 4.7uF MKT EPCOS http://www.diyaudio.com/forums/attac...1&d=1261181853 Bottom trace (white-yellow) is noise floor. Output wires & sense wires cut to 3 cm. I can confirm that placing output cap at load introduced some oscillations, better to keep output cap close to MOSFET. Tried different caps, good results with Panasonic FC and FM, Elna Silmic, Oscon. I think this cap should be low ESR type. Another bypass with 100nF or 220nF and oscillations returns
#387 |
Good info. What load? Roughly what was the ripple on the input? 5V output?
The last image shows ripple close to the noise floor. What would you estimate it to be peak-to-peak? stormsonic, did you receive the email I sent you a few days ago? |
#388 |
Yes, received email today
(sent Dec. 15th)I think problem was in different MOSFETs (IRFBC40 & CEB703AL). Input 12V, shunt current set to 500 mA. Output 5V, load 100 mA (resistor). Look at 2nd picture, lower left corner. Grid is 5 mV, output ripple 3.6 mV peak-to-peak. |
#389 |
Thanks stormsonic. Now let's get to business. 3.6mV peak-to-peak is too much
The images I showed earlier were sub 30-40 uV peak-to-peak. This has happened with about 15cm or output wire (both output and sense). Both latest pcb prototypes same performance. And I don't cheat. There might be something off with your implementation? |
#390 |
Can't be. The Simpler Simplistic HV which is ultra basic was shown with 1mV on an analogous TFT screen scope, long outs, no remote sensing, next to heater wires and valves, with rudimentary CRC input. V2 LV should show just thin line in a digital source environment. Is the Vref filtered with 220uF in your implementation Stormsonic? Or it may be the GND.
| The simplistic Salas low voltage shunt regulator | ikoflexer | Power Supplies | 5070 | Yesterday 03:49 PM |
| Tube for a shunt voltage regulator | jarthel | Tubes / Valves | 14 | 26th October 2006 04:19 AM |
| Page generated in 0.14292 seconds (75.17% PHP - 24.83% MySQL) with 11 queries |
