Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th November 2009, 12:11 PM   #171
ikoflexer's Avatar
A thin flat line, I like that! Well done!
Old 4th November 2009, 12:14 PM   #172
ikoflexer's Avatar
Originally Posted by Salas View Post
I test an SE Mosfet ccs'ed headphone buffer with shunt reg as we speak. AKG 701, Grado SR60. 701 is a pig needs gain. SR60 happy.
Headphones can be extremely revealing. Are you going to let us know the results or should I ask privately?
Old 4th November 2009, 12:47 PM   #173
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its nothing much. An IRF630 CCS'ed underneath at half 18V B+ and 260mA I bias. 0.75A Vbe V1 for both channels. 100VA Tx 2X4700 Elna //, soft recovery diode bridge. Dead silent even on sensitive cans, you need a led to know its on. Has triode type sound. Good tempo and a little upfront but grainless. V1 helped it a lot. Fleshes it out. I need to add a gain stage for insensitive headphones too on input 2. Anyone know a single psu opamp that is cheap, easily available and has smooth sonics?
Old 4th November 2009, 12:54 PM   #174
ikoflexer's Avatar
Why not a use a 2sk170 for gain? Simplistic
Old 4th November 2009, 12:56 PM   #175
Salas's Avatar
Clips early if simple common source. 2N5459 takes 2V p-p but at 6V p-p that CD is clips too. With available B+ that is.
Old 4th November 2009, 01:32 PM   #176
Salas's Avatar
Maybe I will use a normal +/- psu op amp from my drawer by creating a virtual ground, ...it will need yet another ac coupling on its input.
Old 4th November 2009, 02:36 PM   #177
ikoflexer's Avatar
I don't know, but I built two different phono stages based on opamps. Tried various opamps too. Then built your discrete phono and there was just no contest.
Old 4th November 2009, 02:46 PM   #178
Salas's Avatar
Its not something to keep. I was just helping a friend to finish it, because he stumbled. Its great for what it is, and I just want it to have an add on for his low efficiency cans too. Its concept is to be a buffer for efficient headphones. Practical little project, not for critical purposes.
Old 4th November 2009, 05:15 PM   #179
stormsonic's Avatar
http://www.sg-acoustics.ch/analogue_...distortion.pdf
pick up your favorite...
Old 4th November 2009, 08:47 PM   #180
When will a C-Multiplier in front of the CCS-shunt be available?
The simplistic Salas low voltage shunt regulator ikoflexer Power Supplies 4802 Yesterday 01:16 AM
Tube for a shunt voltage regulator jarthel Tubes / Valves 14 26th October 2006 05:19 AM
Page generated in 0.12803 seconds (72.67% PHP - 27.33% MySQL) with 11 queries
