#101 |
Formerly Thanh1973
Most of the guys doing this found they liked the sound of mosfets in the multiplier over bipolar transistors.
#102 |
diyAudio Chief Moderator
Its prefiltering, so it can be good, why not. Don't know about the extra volts needed though if trafo is tight. CMC coils can be good too. I was thinking of a full power BJT cascode CCS instead of the mini only. That would take psrr performance higher for far higher frequencies. I was thinking of a depletion cascode too but then again not much internal feedback, or of an enhancement cascode with 10V Vgs + Vgs that is excellent, ala G. Pimm, could be done with leds, and will go HV too, but then again too much voltage loss. Or a cascode mosfet gyrator? What do you think? I guess will try and listen for a V1.2 at a point.
#103 |
Formerly Thanh1973
I am not sure what is the best soution but a lot of guys liked the mosfet gyrator
#104 |
Cool, I have some boards from my preamp constant voltage load already. Will check in some step upgrade from 1.1 when time allows.
#105 |
Yes, definitely just pre-filter. I would stay away from the lm317, I know other people use it, but it's just my preference.
For high frequency psrr everywhere I looked outside the audio field, guess what they use. Ferrite inductors, and common mode chokes. Simple, cheap, and efficient. Then, two gyrators (or cap multipliers) in series, if one has enough juice in the transformer. There should be enough psrr even for the very obsessed. The noise getting in will probably be only that generated by the shunt reg itself, or modulated by the powered circuit. |
#106 |
#107 |
Last time I got an itch, was the valve itch, and a phono came out.
#108 |
Formerly Thanh1973
Keep right away from lm317
#109 |
Talk about radio interference and its effect on audio stuff. here I quote the view of someone, from a presentation he made:
"The AudioFool Viewpoint • The Myth: “We can hear stuff above 20 kHz” • Reality: Some distortion mechanisms DO produce audible artifacts from ultrasonic signals, but we hear the problems, not the signals! • Intermodulation distortion (40kHz – 30kHz = 10 kHz) • Slew rate limiting within electronics of ultrasonic output of a mic (or of square waves from a test generator)" It's an entertaining document http://audiosystemsgroup.com/Ferrites-Ham.pdf |
#110 |
| The simplistic Salas low voltage shunt regulator | ikoflexer | Power Supplies | 4802 | 11th February 2012 01:16 AM |
| Tube for a shunt voltage regulator | jarthel | Tubes / Valves | 14 | 26th October 2006 05:19 AM |
| Page generated in 0.12044 seconds (75.41% PHP - 24.59% MySQL) with 11 queries |
