Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st October 2009, 08:33 PM   #11
Hello Lewis, I don't have the full EE, just an A.S. in EET. Started working on the Bachelor's but dropped it a couple years ago, long story. Back on topic,
Star882 suggestion is pretty much the same as what I would suggest, so you might as well start there.
Star882, those copper bands around the transformer seem to be fairly common in the Japanese branded amps, I have seen multiple ones that way. All of them were conventional class A/B amps, no switching I know of. Just thought I would let you know my observations, as limited as they are.
Peace,
Dave
Last edited by dave_gerecke; 21st October 2009 at 08:34 PM. Reason: spelling error
Old 25th October 2009, 10:44 PM   #12
jaycee is offline jaycee  United Kingdom
The band is just a screening band.
I agree, red and white is most likely primary. Before you power it on, do some experimenting on the secondaries with a simple continuity test - find out which wires are part of one winding and note down the groups. Then, power on and test, as suggested use a light bulb in series with the hot wire to limit any fault current.
Treat the secondaries as LIVE until you are sure what they all do. None of them should have any continuity with the primary wires - if they do then they could be dangerous. It would be best to screw all of the secondary wires into some terminal strip that you can place probes onto, rather than holding them.
Trio (Kenwood) DP-1000, Any info? GJF Digital Source 49 29th July 2011 02:34 PM
Kenwood Power AMP KM-X1 transformer info space2000 Solid State 0 21st June 2008 12:08 PM
Kenwood L-07M info needed please georgehifi Solid State 33 8th January 2008 07:24 PM
ST-70 Power Transformer Info rudy129 Tubes / Valves 4 10th March 2007 10:23 PM
Looking for a Kenwood L-07MII power transformer Klaude Swap Meet 3 7th February 2007 03:04 AM
Page generated in 0.06596 seconds (80.13% PHP - 19.87% MySQL) with 10 queries
