Hi
I am using a 230v 30va toroidal with 0-12v, 0-12v wired for 24v output. The secondary fuse is a TD 1.25A but at present am using a 0.625A for the primary. Is this to high? Cheers John |
#2 |
Did it Himself
I = P / V
= 30/230 = 0.13A So yes it is too high. Secondary fuse is ok though, could even be a touch higher if you want to draw full rated power from the transformer.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Electrons are yellow and more is better!
You have inrush currents so approx. 1 A slow is OK I should think but you could test with 630 mAT also maybe.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Hi
Thanks for the replies Its the transformer for a millett max headphone amplifer. The 30VA is a little over rated, but anything less than 1.25A blows in the secondary. At present i am using a .635A in the primary - but i will change it ASAP. Cheers John |
#5 |
Did it Himself
You might need a soft start or a slightly higher rated time delay fuse, in the primary. I prefer soft starts
| PSU Transformer ratings? | wildswan | Power Supplies | 6 | 11th May 2006 08:54 AM |
| va ratings for ucd180 | snkby | Class D | 4 | 25th March 2006 01:31 AM |
| Different voltage ratings. | anders.a | Power Supplies | 2 | 4th February 2006 11:35 AM |
| Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) | Rixsta | Pass Labs | 10 | 23rd April 2004 04:41 AM |
| Amplifier Ratings.... | mrfeedback | Solid State | 9 | 8th January 2003 11:26 AM |
| Page generated in 0.08357 seconds (75.03% PHP - 24.97% MySQL) with 10 queries |
