Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th October 2009, 12:04 AM   #21
PB2 is offline PB2  United States
PB2's Avatar
Originally Posted by star882 View Post
20' of tubing wound into an 8" diameter coil yields just over 9 turns. At a spacing of 1/8" between turns, it yields about 18.6uH. Looks like it would be just within reach for a 50kHz switching frequency. Air is virtually lossless as a core material and resistance losses should be small. There might be a more optimal geometry but I'm not sure how to figure it out.
I wonder what's the highest inductance that can be obtained with 20' of tubing with only an air core...
Seems that a spreadsheet where you keep the length constant would help. Or you could take a shot at the Calculus to find a maximum H for minimum length. Someone must have done it, here you go in .pdf:
http://www.phy.auckland.ac.nz/Staff/...;20Problem.pdf
An accurate calculator suggested in the above reference:
http://hamwaves.com/antennas/inductance.html
I believe that more layers will help as a result of mutual coupling, say 3 layers of 3 turns as compared to your 9 turn example.
Old 19th October 2009, 10:40 PM   #22
PB2's Avatar
Star, I noticed that you have several posts about EVs. My nephew is interested in building an EV; he has started, but seems that the cost for batteries, controller and charger is quite high. He's thinking about building them or abandoning the project.
I noticed a DIY controller at the link you provided and I forwarded it to him.
Please let us know how the charger works out if you end up building it.
Pete B.
Old 20th October 2009, 01:46 AM   #23
star882 is offline star882  United States
star882's Avatar
I'm only doing the "design side" of the project for now. I'll actually build it when I need a large power supply that does not need isolation.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 20th October 2009, 02:32 AM   #24
For maximum inductance you'd be trying to approximate a Brooks coil.
I think by the time you figure out your total power switch and rectifier loss, and proper thermal management there, you'll be looking at the slower or at least mid-range side of switching speed. At minimum cost you will probably find gapped ferrite or iron powder most attractive.
Old 20th October 2009, 04:58 PM   #25
star882's Avatar
How much does the core material cost in small quantities?
I did some research on the Brooks coil, and one of the problems is the poor heat dissipation, which the tubing solves by cooling the coils from the inside. I have not found a calculator that can calculate the maximum inductance from a wire of a given length and size. That would be of great help for determining the most optimum geometry.
With lower voltages and/or higher currents, air core inductors can in fact be very practical as the inductance needed would be smaller.
For the EV charger, maybe some surplus microwave oven transformers can be used as inductors. The switching frequency would need to be reduced, perhaps to the point where cheap standard recovery rectifiers and SCRs can be used. The main disadvantage would be the weight. However, a charger with a power circuit consisting of one large SCR, one large rectifier, and a few microwave oven transformers acting as inductors would be very easy for the DIYer to build.
Old 20th October 2009, 10:56 PM   #26
PB2's Avatar
Some surplus parts, that might be of use:
Semiconductors, SCR, IGBT, etc
Old 20th October 2009, 11:38 PM   #27
Star, look at DIY Audio & Video - FAQs, Tutorials, and Calculators for Speaker Boxes, Crossovers, Filters, Wiring and more
on the left side of the page is a section for calculators.
When you get to low resistance coils below .5ohm or so you may want to
do your own math. I don't think this calc displayes results below .1 ohm
or maby that was .01 ohm?
Play with the coil legnth and diameter to find optium size.
Old 21st October 2009, 03:19 PM   #28
PB2's Avatar
Seems a Brooks coil is the most efficient geometry (as Andrew mentioned above) for a length of wire. I believe that if you provided say a 1/16" gap between layers and windings for air flow that you'd end up with good enough cooling just with passive cooling. 6 turns X 6 layers is 36 turns with a box of about 1.5" and a 3" core; this calculator predicts about 125 uH:
Ness Engineering Tech Data - Brooks Coil Formulas
Old 26th October 2009, 03:18 PM   #29
star882's Avatar
Maybe the idea is more practical than I first thought. Perhaps it can even be used in a high current boost converter to step up, for instance, 288v from the battery pack to 400v for operating a motor inverter as well as step it back down during regen. (400v is about the peak value of 277v AC.)
Old 7th November 2009, 03:17 PM   #30
star882's Avatar
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
That project aims to allow common 3 phase industrial motors to be used for homemade EVs. One problem is that most industrial motors operate at 208-230v minimum (for rated power), which translates into 300-325v plus overhead of DC. Not exactly practical for a battery pack. But to step up a 180v battery to 400v with a maximum load current of 200A (translates into about 100HP) at an operating frequency of 15kHz only requires about 16.5uH. That is practical for a copper tubing inductor cooled with oil. One major problem is that the metal of the car would act as a shorted turn. However, hypermilers often add "Kammbacks" to their cars. If the Kammback is made from a nonconductive material, the inductor can be installed inside it in such a way that the metal would be far away enough to not cause problems. I'm not sure about heat dissipation of 1/4" tubing when conducting 200A, but I would not expect it to be a problem as the load would usually be much less, maybe as low as 15A when cruising.
Copper foil versus wire in inductors klitgt Multi-Way 43 6th June 2006 05:18 PM
Good Source for high current Inductors?? Zero Cool Pass Labs 5 14th November 2004 12:36 AM
copper foil inductors dave k Multi-Way 1 1st June 2003 01:02 AM
Copper foil inductors. JoeBob Multi-Way 5 22nd April 2002 07:39 PM
Page generated in 0.11978 seconds (80.13% PHP - 19.87% MySQL) with 11 queries
