Using the HYPNOTIZE as a general shunt reg PCB
Old 31st May 2013, 11:20 PM   #611
c_door is offline c_door  Italy
Hi Siberia,
you mean the turntable ?
I've just restored my beloved Thorens TD125Mk2, bought it some 35 years ago..
The motor wasn't spinning anymore, it was enough to replace a couple of 1000uF caps,
a common fault with this table.
My plan is to build a new plinth and replace the old tonearm with a Jelco 750, and maybe a Dynavector cartridge in place of the venerable Stanton 681.
Old 4th June 2013, 11:03 AM   #612
Siberia is offline Siberia  Lithuania
Siberia's Avatar
I've certainly meant TT, but have no idea why I wrote Tx. Thanks for reply.
Old 4th May 2014, 01:45 AM   #613
laughingbuddha is offline laughingbuddha  United Kingdom
Are these PCBs still available ??
Old 10th December 2014, 02:34 PM   #614
dmtparker is offline dmtparker  Panama
I do not see an answer. In the store I only see Mesmerize boards. What about pdf of boards to make my own? I have seen a variety in different posts, but am not sure which pdf design is the same as the hypnotize boards.
Old 10th December 2014, 02:46 PM   #615
Originally Posted by Salas View Post
Your parts and DC input are good enough.
OK, I shanghaied this quote to post my question.
I am thinking of using this design for both a pre-amp and a crossover based on the B-1 topology, so I am looking at powering about 10 B-1 'modules' per side. If a complete B-1 draws 20mA (stereo), then I should be drawing about 200mA. To be safe I should double that and design for 400mA, yes? Also, I have a good source of pure DC @ 50V. With a voltage divider I can get +/- 25VDC. What happens if I put 25V in for 10V out (instead of +7V)? Should I use a series regulator first to drop V to 17 or so?
Thanks for the help.
Old 10th December 2014, 03:16 PM   #616
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, double current capacity is good. With 15V Vin-Vout dif VS 7V you get more dissipation on the CCS MOSFET but better CCS PSRR frequency because the MOSFET levels out for capacitive parasitics at that VDS. There is the hot-rod Hypnotize DCB1 successor board and the BIB regulator board still in periodic circulation that you can use.
Old 10th December 2014, 08:16 PM   #617
I do not see them in the store. Where/how do I get them? Is there a 'sign up'?
Old 10th December 2014, 08:49 PM   #618
Salas's Avatar
See in the group buys section.
Old 10th December 2014, 10:14 PM   #619
I only looked in store.
Old 10th June 2015, 10:49 PM   #620
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Gentlemen, a DIY-friend of mine left me his partially built "Direct Coupled B1-Buffer with Shunt Regulator" - see attached image.
For example: he has already soldered all of the 2SK170 transistors.
I have finished the PCB yesterday and did some measurements / tests. The transformer used is a 2x12VAC / 50VA toroid.
All LEDs are shining and no component is getting hot.
But:
1st: I had troubles with the relay. It would not switch on. I finally replaced the BC550 (the upper one) by a 5V1 - ZENER - diode. Now the relay switches on after about 4-5 seconds.
2nd: I measured the positive rail-voltage (10.5V) and the negative rail-voltage (9.5V !). So there is > 1V difference. Is this tolerable?
I have measured and selected the LED-strings by myself. They are definitely o.k.
3rd: I measured 1mV DC-offset (I have measured between Output and GND) on one channel and 10mv (!) on the other channel.
Is this a "usable" buffer or do I need to fix anything?
Best regards - Rudi_Ratlos
Using the HYPNOTIZE as a general shunt reg PCBHide this!Advertise here!
General purpose shunt regulator Lumba Ogir Solid State 76 13th August 2017 03:31 PM
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 11:50 PM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 10:47 PM
