Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st July 2011, 07:43 PM   #531
acidbrain's Avatar
Yes, i did read that in the manual for the BiB shunt. But with more uF the sound from a certain cap ( Obbligato in my case) will also be stronger present in the music, maybe too much. I want to adjust the sound, for me that's even more important than have the best filtering. This adjusting to optimal will take a lot of time.
The surface is varnished, but the layer is very thin. Maybe I can use a wire on a cleaned part of the cap and then use schrinking tube to isolate the cap.
The wires of the cap can also touch the copper tube, so isolating is a good thing here.
Old 21st July 2011, 07:47 PM   #532
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If you have ears and time for fine tunings its a nice thing, there are always things to try.
Old 21st July 2011, 08:04 PM   #533
acidbrain's Avatar
That finetuning would be a lot more difficult to do if I didn't had your shunts Salas !
Old 28th November 2011, 11:51 PM   #534
buzzforb's Avatar
What importance do resistor choices play into using this as just a PSU. I know i could read through 2000 pages of various comments, but am short on that kind of time.
Old 29th November 2011, 07:09 AM   #535
Salas's Avatar
Beyond using low ppm with proper wattage not to get hot for the voltage ref resistor value you are going to end up with, don't bother.
Old 29th November 2011, 08:59 AM   #536
buzzforb's Avatar
Thanks for the quick reply.
Old 16th December 2011, 01:27 AM   #537
buzzforb's Avatar
Salas,
You give an explanation on how to figure numbers but is there a link to a description of how the circuit functions. I think I have a general understanding, but would like to know more specifically how it all works. Only shunt regulated article I can find is Jungs differential version.
Old 16th December 2011, 01:38 AM   #538
Salas's Avatar
I had written several times in the threads. In general the input section consists of a Mosfet constant current source held open steadily by the leds and a resistor fixes its current. A jfet ccs makes the leds even steadier. That is to insulate the regulator from the rectification in both directions. The voltage reference is made up by the more leds, again Jfet ccsed. That reference the bjt compares to the output and gives correction signal to the shunt output mosfet. The bjt has another ccs for load than just a resistor. Increases its efficiency. What current is extra to consumption and coming from the main Mosfet CCS is shunted to ground keeping the shunt Mosfet low impedance. That's about it.
Old 16th December 2011, 08:47 AM   #539
buzzforb's Avatar
Thanks. I am new to BJT's, only using fets up to this point, and wasn't totally sure if this was the control mechanism. I also found DougL's writeup in the wiki. I noticed that in the BiB, you switched to the 117 vs 170, would the performance gain be similar in this setup?
Old 16th December 2011, 09:59 AM   #540
Salas's Avatar
No, don't switch in this one.
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 44 7th October 2009 07:01 AM
General purpose shunt regulator Lumba Ogir Solid State 73 12th February 2009 09:00 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
Page generated in 0.10355 seconds (74.73% PHP - 25.27% MySQL) with 11 queries
