Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st January 2011, 11:27 AM   #491
you are in the wrong Thread.
But, yes, the Blue Hyp has dual caps for each supply and can be rC or rCRC or rCLC as you wish.
Check out PsudII for comparison of the filtering effect.
Old 31st January 2011, 11:34 AM   #492
acidbrain's Avatar
Thanks and I want to keep this thread alive because here is explained how to adjust hypno + Blue.
That PsudII software looks promising.
Old 13th April 2011, 04:10 PM   #493
I'm trying to follow these instructions with a Hypnotize blue edition... where's the 10R resistor I'm supposed to be using to measure the current?
Old 13th April 2011, 04:48 PM   #494
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
On the board, it is near the four big caps, listed as 2 x 47 and beside that 10/5w
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 13th April 2011, 05:39 PM   #495
Thanks. The CCS section also mentions " Choose 2 parallel 1W resistors for each side to install in the marked 2x 68R positions" Is this the same resistor?
Old 13th April 2011, 05:49 PM   #496
Tea-Bag's Avatar
Yes, that's for the older board. But all one and the same.
Old 15th April 2011, 01:52 PM   #497
I put 10R resistors there and I'm measuring a 2 volt drop, which I guess comes to 200ma. I'm using the board to regulate the power off of an SMPS that's rated for 400ma, but when I turn it on, the power LED on the SMPS switches on and off. I'm wondering if it's having problems charging those capacitors. Do I even need the caps since I'm using DC input rather than AC?
Old 15th April 2011, 02:17 PM   #498
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Skip the (bridge?) and capacitor rectifying section. If the SMPS still acts up, maybe 50% its current spec in constant draw is not tested for, lower the CCS current near to your max load's demand +50mA.
Old 19th April 2011, 02:45 PM   #499
I removed the caps and now the smps seem happy...
Is my math right here?
49v input
2.35v across the 10 ohm resistor
1.4v across the 220ohm
output is 5.97v
current = 235 ma
Base voltage is 5.97 - 1.4 = 4.57
Target voltage is 30v, so 30v - 4.57v = 25.43v
25.43v/235ma = 108ohm
I tried a 110ohm resistor in place of the 220 and I'm getting only 5.3v output
I put a 5.1k resistor in and I get 37v, so I'm guessing I moved a decimal place somewhere...
Old 19th April 2011, 02:59 PM   #500
acidbrain's Avatar
5.3V is that with the load attached ?
Do you have a picture of the hypno?
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 44 7th October 2009 07:01 AM
General purpose shunt regulator Lumba Ogir Solid State 73 12th February 2009 09:00 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
