Using the HYPNOTIZE as a general shunt reg PCB - Page 13 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th March 2010, 11:48 AM   #121
merlin el mago's Avatar
Originally Posted by Salas View Post
Roughly 2.2V/R gives the current as I say in post #1.
Ok now understand, 2.2V is the current trought the resistor so:
2.2V / 11R = 0.20A
And for 130mA:
2.2V / 16.5R = 0,13A
Old 12th March 2010, 12:16 PM   #122
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by merlin el mago View Post
Oooops, looking for RCA connector for RIAA I get these nice caps suitables for C5 Shunt reg. PSU
BG WK Power Tank 220uF/200V, wow, can be suitables?
If they fit.
Old 12th March 2010, 12:19 PM   #123
Salas's Avatar
2.2V / 11R = 0.20A
And for 130mA:
Yes, rough guide for projecting values. LEDs, Vgs, vary between parts and voltage levels wanted. If you measure your Vdrop across Rset on your own build you will calculate exactly on first test.
Old 17th March 2010, 04:43 PM   #124
Default +-24V 100mA
For more than +-20V where is necessary to use the 1W rated resistors?
Wich is the voltage to match LEDs?
As I understand no matched 2SK170BL needed for mine setup, right?
Old 17th March 2010, 04:57 PM   #125
Salas's Avatar
The Vref set resistor drops enough voltage for 24V so it dissipates. Yes 1W.
Read again post 1 for all other questions.
Old 20th March 2010, 04:27 PM   #126
Wich will be the value of load resistor for 24V 200mA, to check the Vout?
Old 20th March 2010, 05:04 PM   #127
Salas's Avatar
2X1k 1W in parallel.
Old 20th March 2010, 09:44 PM   #128
Thank you so much.
Old 21st March 2010, 03:24 PM   #129
Is possible to full populate the Hypnotize to use inside the Simplistic Phono RIAA to have in one box Phono pre-amp+Headphone amp or pre-amp/line-amp?
Old 21st March 2010, 03:32 PM   #130
Salas's Avatar
The Hypno has no gain of its own, so it can be in same box with a volume control if the power amp is about 0.5V sensitivity, because the simplistic is not a CD player. Most tube amplifiers can certainly be driven full.
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 10:50 PM
General purpose shunt regulator Lumba Ogir Solid State 73 12th February 2009 09:00 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
Copyright 1999-2017 diyAudio
