Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th October 2009, 05:33 AM   #1
Default Switch mode PSU
I have trouble with this. I have done a few by swapping in caps but this one is blowing fuse. I am by no means skilled in electronics but would like to be. Only failures and successes are going to teach me. Any advice would be greatly appreciated.
Old 16th October 2009, 05:48 AM   #2
Enzo is offline Enzo  United States
IMPORTANT
These switchers run directly off the mains - your incoming AC power is directly rectified into high voltage DC with a ton of current behind it if it wants. These are extremely dangerous to service. ALWAYS use an isolation transformer at the very least.
Whe I have a small switcher for service, first thing I check for is shorted semiconductors. Check all the secondary side rectifier diodes. Be aware ther are often load resistors to provide minimal loading, so you might see 100 ohms appearing across a diode, but a short is a short usually.
I always check the switching transistors. They can fail on their own, or becuase of something shorted elsewhere. Certainly the main primary side rectifiers.
Old 18th October 2009, 11:08 PM   #3
bountyh is offline bountyh  United States
If you are blowing fuses, you have to replace AT LEAST:
Switch transistors
Output rectifiers
IC that drives the switches
Switcher filter caps
Switch Mode Design.....help? MotoMan_Yz400 Chip Amps 8 31st January 2008 02:07 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 10:15 AM
Switch mode noise NickC Power Supplies 5 14th December 2005 01:37 PM
switch mode Retsim_X Power Supplies 0 18th September 2005 12:55 PM
switch mode supply R. McAnally Everything Else 6 26th December 2002 02:22 AM
Page generated in 0.07347 seconds (65.82% PHP - 34.18% MySQL) with 11 queries
