I am looking for a way to use either a couple of LM337 in parallel to get 4 amps or lm723 with (2) PNP power transistors to get negative 25v and 4 amps. I think I could get it with the LM723 and (2) MJE2955. but my knowledge is limited on how to construct it. I studied the LM723 paper and am confused on the pinouts. any help appreciated.
thanks soap |
#2 |
hello.
a powertransistor parallel with a voltreg. can do that............but often the problem is heat dissipation. what kind of application is it? are the 4 ampere continuous or only short current peaks? greetings.............. |
#3 |
application is a 30-40w audio amp with peak current around 4amps. I tried to use unregulated supply but could not get a 120 hz hum out from rectifier. no matter how i routed my grounds or how big my caps were. it uses dual rail 27vdc power. I found this schematic at national using an old LM333 power regulator. I thought I would use LM337 in it's place. But I think an LM723 with a couple of power transistors would work better less noise. I have to study up on power transistors and the LM723. the LM723 doesn't look too easy.
thanks for reply.. soap |
#4 |
.........so the problem is the 120hz humm.
usually with a few 1000uf per rail an amp works without humming. perhaps there is a bad rectifier(-diode) or something else....... the lm317/lm337 are often used.........have a look at the forums here - there are some psu examples that use them. greetings.......... |
#5 |
Definitely your hum problem isn't the lack of a regulator. I'm sure if you post details about your build you'll get help to get rid of the hum.
| Negative Feedback | AmpBuilder225 | Tubes / Valves | 7 | 20th February 2009 09:05 PM |
| Regulated or non-regulated SMPS | longitude | Class D | 5 | 8th May 2007 04:02 PM |
| Get away from negative feedback ? | N-Well | Pass Labs | 3 | 1st March 2006 11:17 PM |
| Negative feedback? | Solid Snake | Solid State | 33 | 14th March 2003 02:29 PM |
| Can I use a 4Amp Mosfet in a Zen | Shoog | Pass Labs | 3 | 23rd September 2002 06:42 PM |
| Page generated in 0.07593 seconds (71.75% PHP - 28.25% MySQL) with 11 queries |
