Greetings!
If I have neither capacitance meter or ESR meter, how can I now if a capacitor is good or faulty. It has no visible defaults. If the answer is that I have to buy one of the above testers, which should I get. I'm thinking ESR. And I have yet to see a capacitance meter that can meusure above 20000uf. It should also be said that in my househould the budget for this kind of thing is strictly limited. Regards, Erik |
#2 |
why would you need to meter caps above even few uF?
if cap holds rated voltage, the is probably is good, no? |
#3 |
Actually, given nothing else, if the cap holds voltage it's probably quite healthy. Still, there's nothing like knowing for sure, so I show you how to build a simple cap bridge using next to nothing here- http://www.conradhoffman.com/chsw.htm
If you have a good junk box or improvise, you should be able to do it for just a few dollars.
I used to be an audiophool like you but then I took an arrow to the knee. |
#4 | |
Electrons are yellow and more is better!
ESR is only important if you drive them hard like in a switched power supply and some other heavy duty operation.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
thank you everyone, @ Peranders, they're old. Well, used. And how would I know if they hold rated voltage?
#6 |
If they are dry the will have increased leakage and in general bad function but one easy way to find out is to charge them via a resistor, 10k or so and turn up the voltage so you will get 1-5 mA leakage. Let the current flow for some time and see if it will get less. If it tends to increase you have reach the voltage rating. A 35 V cap starts to leak at 42-48 volts if it's OK. It's important that you have a resistor in series because otherwise the cap can explode if you have a powerful voltage source.
How old are they, brand, type, capacitance, voltage rating?
#7 |
And the simple answer - charge the cap up, remove the charging supply, then measure the stored voltage with a meter.
#8 |
Or charge the cap with a constant current. Measure the time it takes to reach a given voltage and calculate capacitance.
Or charge the cap to a given voltage and put a known distcharge resisitor- remove source and measure the time it takes to discharge, then calculate capacitance.
http://www.switchmodepowersupply.net |
#9 |
Thank you airbody. This might all work for you. But I'm sort of a layman so I just bought an ESR meter. I also just put it to good use. I have had a NAD C350 awaiting repair for a long and desperate time. In a few minutes with my meter I meusured all the caps in the amp IN CIRCUIT. I discover FOUR of them was open. I changed them, and now I'm dancing away in my living room.
Ta'
| Testing PS filter caps | Conrad Hoffman | Parts | 23 | 20th December 2009 03:55 PM |
| Best method(s) for testing PS caps? | clm811 | Solid State | 16 | 1st October 2009 12:44 PM |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 11:17 PM |
| testing second hand filter caps | Wagener | Solid State | 4 | 2nd May 2004 03:14 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 02:02 PM |
| Page generated in 0.09825 seconds (77.15% PHP - 22.85% MySQL) with 10 queries |
