#11 | |
#12 |
Banned
I just found these battery management ICs specifically for LiFePO4 batterries - MCP73123 - available in Mouser $1.50. Has anybody used them or got any spare to send me?
#13 |
Hi Jkenny,
I'm also searching for a simple charger for a Hyperion LiFePO4 battery powering the digital part an ESI Juli@ soundcard. Are you using HyperionA123 batteries ? For these, I'm afraid MCP73123 would not be adequate, as the standard charge methods are: 1100mAh: 1.5A to 3.6V CCCV, 45 min. 2300mAh: 3.0A to 3.6V CCCV, 45 min. and MCP73123 is limited to 1100 mA. Not 100% shure, but CCCV is CC and CV charging (CC first, and, as as charge goes on, the current charge is then voltage limited). A L200 regulator can do that, except swithing off after 45 min. For SLAs, it's better to charge it individually; do not know for LiFePO4, but can't be wrong doing it. Best regards, Alain Last edited by alain_online; 11th October 2009 at 02:03 PM. |
#14 |
Banned
Alain,
You seem to be correct, I overlooked the specs on these but should have noted that they are meant for mobile devices so probably limited current. Here's a cheap single charger for $13.75 which seems to suit - only problem is shipping is US only http://www.all-battery.com/tenergyli...rger01300.aspx I've too many things to DIY & an off-the-shelf solution appeals to me now. Yes, I have the Hyperion A123 2.3Ah batteries (good prices). Individual charging is recommended - all the muti-cell chargers have balancing circuits to protect individual cells from overcharge (>3.7V) damage, so my simple approach would be to charge individually but in parallel. Where are you using your batteries & with what result? I'm only starting to use mine so too early to give any feedback but I intend to power a ESS Sabre32 DAC with some of these. First, I'm experimenting with them on powering a Musiland USB DAC pcb & ESS 2 channel Vout DAC as well as a Tripath (TA2020) amp. Last edited by jkeny; 11th October 2009 at 03:00 PM. |
#15 |
Jkenny,
My little experience with batteries are with tube heaters, Fertin's driver field coil and for cathode bias. Except for the last on, I liked the result more than the on I had before. Just subjectively cleaner, looking deeper in music; not tested anything. Now, I have not yet powered the Juli@ soundcard, so I can't tell anything about it. I'm using it with cMP PC audio setup, with I2S to Sabre DAC. On my to do list about batteries: power my Sabre DAC and the computer. For monitoring discharge, I found a little voltage comparator, which seems simple to implement (see: "simple comparator" in application notes) : LM139. Best regards, Alain |
#16 |
we all need the poor man solution! is there someone who arranged to feed a ta2020 with a li-ion notebook battery?
do you think it may be possible to use a 60W step up converter boosting a 7.2v to 14.4v with a ta2020 amp? they're rated from 5000 to 10000 mah... and the only expense would be the converter and a low battery alarm. |
| Best Loudspeaker Management System | a007udio | Multi-Way | 27 | 12th February 2011 10:49 PM |
| High Sensitivity Subwoofer for 12v battery based system | jason_watkins | Subwoofers | 13 | 31st October 2009 07:04 PM |
| Amps for a 12v battery based sound system | jason_watkins | Class D | 2 | 29th September 2009 12:34 PM |
| Digital Speaker Management System | Jeroenkv | Multi-Way | 2 | 26th September 2007 09:26 PM |
| Efficient spkr req' for battery system. | Mark25 | Multi-Way | 9 | 3rd December 2003 08:52 AM |
| Page generated in 0.11215 seconds (77.15% PHP - 22.85% MySQL) with 10 queries |
