Hi all,
I have a transformer taken from an aiwa P80 defunct amp. Secondary voltages are 60VCT and I think a 12V or so. The problem is that I have 4 primary wires. Black, Yellow, Orange and White. The amp had voltage selector for 110V 220V and 240V. I need the 240V setting. I tried once and blew the power board circuit breaker. Hmm, I need help please. Only thing I can think of is to put say 9 volts on the secondaries and measure the primaries but, is there another (safer) way to do this.
Terry
Terry
And how does 2 windings that go in either series or parallel give you a choice of 110, 220V and 240V ?
I have no idea! It gives either 110 or 220 in series or parallel. Wouldn't the wire guage have something to do with it?
Terry
No, the wire gauge wouldn't affect the voltage.
If you have a choice of 4 voltages, and only 4 taps on the transformer, I would expect one 0-240V winding with 2 taps, one at 110V and the other at 220V.
If you blew the fuse, you either wired the secondary to the mains, or the 220-240 section to the mains. Which means you had 240 * (240 / 60) volts or 240 * ( 60 / 20 ) - i.e. you exposed yourself to 960 Volts or 720 Volts.
Either way, you could have killed yourself.
edit: corrected an error in the math.
Thanks for the reply.
I know which ones are the secondaries. They are terminated with plugs.
What I think I did was to connect the primaries wrong. I have since measured the resistance and I think sorted out which wire is which, well I am assuming that the two wrires with the most resistance should be at each end of the primary.
I also know that the wire size has no effect on the voltage, but does the primary side effect the current draw.
PS. The power board I use has a good circuit breaker etc.
Terry
