Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st December 2009, 08:23 AM   #11
Atilla is online now Atilla  Norway
Soldering Gun Fanatic
Nothing related to the transformers themselves was causing this, I tried quite a few things to rule them out.
It is possible that the lid might touch those cables, so I'll take a more careful look at them when I come back from holidays. I need to secure them better and pair them up in heat shrink anyway, so I'll position them in a different way. I'll report back my results if that helps.
Old 31st December 2009, 09:38 PM   #12
robmil is offline robmil  United Kingdom
The transformer is a toroid. The secondaries are quite a distance from the lid (7-8cms).
The secondary cables are quite long - 13cms and run along the length of the chassis bottom. The secondaries are twisted together which has reduced the hum A LOT. The transformer is 50va and only about 5cms high.
It's only when I bring the lid (aluminium) close to the chassis when the hum (50hz) starts to be audible through the loudspeakers.
Would it help if I shielded the secondaries using a steel woven screen and attached the screen to the chassis.
Happy new year
rob
Old 1st January 2010, 01:12 AM   #13
godfrey is offline godfrey  South Africa
That's different. The OP had mechanical hum from the amp itself. If you're getting hum through the speakers the pre-amp circuitry must be picking up a hum field. Maybe some steel or mu-metal shielding would help?
strange sound from transformer when load increased jegandren Power Supplies 8 21st September 2008 10:29 AM
Strange Transformer Question..... wildswan Tubes / Valves 4 25th May 2006 12:32 AM
Strange transformer problem jarkaa Chip Amps 2 9th November 2004 08:00 AM
Brazil, and some strange laws, not too much strange! destroyer X Everything Else 0 11th September 2004 12:38 PM
strange transformer failure mode capslock Solid State 9 27th March 2003 09:58 AM
Page generated in 0.09536 seconds (68.90% PHP - 31.10% MySQL) with 11 queries
