Sorry for the simple question, but I've done quite a bit of searching around & haven't found what I'm looking for....
If I have a power transformer that is labelled with a 230v primary & 46v-0-46v center tap secondaries, can I assume that it is useable with US 120v mains? The output will instead be more like 23v-0-23v, right? Does the current capacity of the primary go up & the secondaries go down in this scenario? If there's a link that you can point me to, that's good to. Thanks! |
#2 |
Yes, it should be usable. The current capability is probably limited by its windings so in general won't increase - thus the transformer VA rating would be halved.
#3 |
My understanding is it will work with reduced output voltage.
However you must not exceed the rated output current. If it is 2 amps at 46 volts then 2 amps at 23 is the max. This is down to the guage of wire used for the windings. |
#4 |
| Case: Naka RX-202 120V to 230V convert | PaleRider | Everything Else | 3 | 13th February 2009 05:50 AM |
| From 230V 3pin to 120V 2pin? | jkeny | Power Supplies | 7 | 6th March 2008 05:32 PM |
| My new CD371-120V or 230V | ZuMbAiU | Digital Source | 0 | 14th May 2006 04:24 PM |
| Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers | Eva | Swap Meet | 1 | 28th July 2005 03:00 PM |
| 120V QSC PLX 230v conversion??? | bOOgy77 | Class D | 1 | 5th December 2004 07:25 PM |
| Page generated in 0.08174 seconds (73.48% PHP - 26.52% MySQL) with 10 queries |
