Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th September 2009, 06:35 PM   #1
Default Duncan's amp Mosfet Regulator
I can't find a post that references this design on the forums. For those that don't know it it's here: http://www.duncanamps.com/technical/mosfet.html . Is it largely thought that this design is outdated? Do people generally use the Maida type design now?
I'm planning to use these in a guitar amp, a variable one for the power amp, and a fixed one for the pre amp, if that makes any difference.
Any help is appreciated.
Old 19th September 2009, 07:25 PM   #2
SY's Avatar
It's a good design (though I wonder about the stability and noise without an output cap). It's unlikely to be significantly better than a Maida, and a Maida is simpler and cheaper. The Maida isn't the be-all and end-all, but it's good performance for something that simple, and for stages with reasonable PSR, it's "good enough." As is the simple diff-amp regulator like Duncan's.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Series MOSFET regulator better with just voltage ref on gate or with error amp? ray_moth Tubes / Valves 69 20th May 2011 01:35 AM
Simple opamp/mosfet shunt regulator ikoflexer Solid State 64 12th March 2009 06:38 PM
Low-parts high voltage MOSFET regulator arnoldc Power Supplies 1 6th June 2006 10:25 AM
Mosfet Regulator Question Rory Christ Pass Labs 0 28th March 2004 02:35 AM
Need help with Duncan T500 MosFET Amp. Hoffmeyer Solid State 0 13th July 2002 03:25 PM
Page generated in 0.07754 seconds (70.81% PHP - 29.19% MySQL) with 10 queries
