Go Back   Home > Forums > Amplifiers > Power Supplies
Closed Thread
Old 12th September 2009, 12:24 AM   #1
Unhappy Need Help In making power supply! :(
Please I really need help here, I don't know where to start, I'm just a college student.
I'm given the facts that:
1. Input AC voltage is 220v (RMS) at 60Hz.
2. Output Dc voltage (unregulated-no regulator)
- 9v, +5%, -5%
3. Maximum Ripple factor 3%
4. Maximum Load Current 250mA
Please help me, As soon as possible.
Old 12th September 2009, 02:57 AM   #2
star882 is offline star882  United States
star882's Avatar
12v wall wart (at least 300mA rating, preferably 500mA or above) and a 7809 regulator.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 12th September 2009, 02:56 PM   #3
Do you mean you aren't allowed to use a regulator?
Getting 10% regulation (+/- 5%) on a power supply as small as 250mA is not likely without a regulator. The bigger the transformer, the lower the regulation, meaning less variation between idle and load output voltage. If you are able to use a regulator, what star882 said is correct.
Tyler
Old 12th September 2009, 03:01 PM   #4
Default voltage regulation.
if the mains varies by +-6% then one has no hope of meeting +-5% voltage tolerance.
regards Andrew T.
Old 12th September 2009, 03:25 PM   #5
keantoken's Avatar
It looks like you need to check back with your teacher and make sure your requirements are correct.
- keantoken
Old 12th September 2009, 06:19 PM   #6
DougL is offline DougL  United States
- 9v, +5%, -5%
The way I read it is you need to design a 5V ps with 150 mv of ripple, and a 9V ps with 270 mV ripple.
Download PSUD2, and give it a try. There are a couple of articles on the web on how to use it.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 13th September 2009, 11:50 PM   #7
Gordy is offline Gordy  United Kingdom
- 9v, +5%, -5%
This is your first post, right?
You joined the forum for this, right?
You're not actually going to use this, right?
You just want to USE US TO DO YOUR HOMEWORK, right?
And you want us to do it for you 'as soon as possible' so you can hand it in on time, right?
You want to suck on our good will to compensate for your pathetic lazyness, right?
And you think that we have nothing better to do, right?
Learn it the normal way, and use the example in the text book just as your tutor showed you.
(...said Gordy, not known for sitting on fences).
Last edited by EC8010; 14th September 2009 at 05:55 AM. Reason: Inappropriate language (but appropriate sentiment).
Old 14th September 2009, 12:19 AM   #8
MJL21193's Avatar
Bravo!
Old 14th September 2009, 02:35 AM   #9
keantoken's Avatar
I would state it more politely, but I do agree that someone going into EE should listen to the professor speaking... Engineering is not for the fainthearted.
- keantoken
Old 14th September 2009, 05:59 AM   #10
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
My attention has been drawn to this thread. Please don't let that happen again.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Closed Thread
making ones own power resitors for a son of zen mark Pass Labs 12 17th February 2010 04:17 AM
Making your own winding for auxiliary supply rtarbell Parts 2 4th March 2008 07:36 AM
Anyone making SMPS for power amps? mr.duck Parts 15 17th April 2007 11:32 AM
active crossover power supply pcb check before making mazurek Solid State 20 2nd May 2006 12:17 AM
active crossover power supply pcb check before making (was in wrong forum) mazurek Power Supplies 0 29th April 2006 10:25 PM
Page generated in 0.13871 seconds (72.28% PHP - 27.72% MySQL) with 10 queries
